I installed the rest of my frame sliders from motovation. Got the front, rear and engine ones done... and did the rim tape yesterday
Thanksshineyyy
Looks great, but hurry! These black tanks will only retain that glowing sheen for about 27 seconds before it starts showing every single imperfection and speck of dirt again! :smilielol5:Thanks
ill take her outside this afternoon, take some pics & see what she looks like in sun.
Sent from Motorcycle.com App
Get the spreadsheet on this site to help you measure the correct shimso....i did my first valve check today (skipped it at 10k) and got some somewhat worrying results. i wanna know what your opinions are?
my bike is a '12 R w/20k miles that i commute on every day and it sits at 8k rpm pretty much all the time. i'm attributing this to my results.
from left to right:
EX: .356 / .356 / .356 / .381 / .381 / .356
IN: .127 / .127 / .152 / .152 / .127 / .127
so all my exhaust valves are way loose. should be (.275 - .325mm), intakes are all good though (.10 - .20mm).
can i attribute these results to high EGTs from running constant RPMs for long distance?
guess i'm pulling off her girdle tomorrow.. :curtsey:
Why are you worried about the results ???so....i did my first valve check today (skipped it at 10k) and got some somewhat worrying results. i wanna know what your opinions are?
from left to right:
worried because either my head wasn't machined well (likely) or the valve seats are dropping from high EGTs?? (i'm a diesel guy...common problem)Why are you worried about the results ???
Valves clearances (especially the exhaust) tighten with use ........
shimming is easy, no spreadsheet needed. my Hot Cams kits only have .05mm increments, so it's really either one or the other.Get the spreadsheet on this site to help you measure the correct shim
taken the other day, needs to be watched at 720 or so resolution
was a bit of harmless fun.
Thank you kindly "Cobber", showing my agePretty good soundtrack "mate". 1st I've heard the Cure on a bike clip. Refreshing after a plethora of Kenny G inspired techno crap and Deftones Nu Metal B.S.
Not at all Guv'ner. Most Cure fans 'round these here parts is them younguns.Thank you kindly "Cobber", showing my agewith that one.
Cheers
Peter
