Thanks to those that entered and also to those who voted! :thumbsup::thumbsup:
BOTM is BACK!
Congratulations to Orangeman and his magnificent 2010 Street Triple R
Fantastic machine with lots of performance minded upgrades.
2010 Street Triple R - Matte Orange
Zard 3-1 full exhaust
Matris MO5-R rear shock
Matris FO5-R 25mm fork cartridges
EVR TCS slipper clutch
Triumph quick shifter
Sato billet shifter rod support
1050 throttle tube
Manual CCT - Triumph
Aspirazione Racing billet velocity stacks
DNA street filter
Custom Dyno tune
MOSFET R/R upgrade kit - Triumph
Lightweight lithium iron battery
Scorpio alarm with perimeter sensor and page alert
Michelin Power Pures
D675 stock rearsets - cermicoated black
Rear hugger - Triumph
Ceramicoated round headlight bowls - black
Sylvania Moto-Vision bulbs
2w LED position bulbs - hyper white
Cibie headlight lenses
SS intake screen
CF mini radiator cowls
CF heel guards
CF seat cowl
CF exhaust guard/heat shield for clutch cable and coolant hose
CF plate frame
Advanced Engineering exhaust slider
HEL brake lines - SS/black - dual front and rear
Pazzo levers - long - black/titanium
Rizoma Dynamic mirrors - black
Rizoma - Minus 10mm bar risers
GSG billet mirror extensions - black
Rizoma front and rear billet brake reservoirs - black
GB Racing clutch/balancer/stator covers (case sliders)
R&G Aero frame sliders
R&G cotton reels (spools)
R&G fork sliders
R&G bar end sliders
R&G radiator guard - black
R&G billet shark fin - black
Super Moto Engineering billet axle blocks with swing arm sliders
TWM ¼ turn fuel cap - titanium
Ermax tail tidy/undertail - textured and painted to match stock black plastic
Passenger peg mounts removed
Rear peg filler panels - color matched -Triumph
Mini LED "arrow" rear indicators (stock shape but smaller)
Weiser front signal LED inserts
Electronic signal flasher relay
Tech Spec snakeskin tank pads
Drive systems Superlite sprocket
EK MVXZ+ nickel chain
EBC FA347HH front brake pads - FA140 rear
ELF HTX115 brake fluid
Billet shifter arm - Triumph - black
Billet dipstick - Triumph - black
Evotech billet oil filler cap - black
Ti Front and rear brake caliper mounting bolts
Ti Front caliper pinch bolts
Ti front and rear brake rotor mounting bolts
Ti front axle pinch bolts
Ti exhaust mounting bolts
Ti triple clamp bolts
Ti clutch and brake lever perch bolts
Ti mirror mounting bolts
Ti front and rear brake pad slider pins
Ti bleed nipples - all
Ti axle slider mounting bolts
Ti rear axle adjuster nuts and bolts
Ti rear brake caliper slider bolt
Ti Gilles rear axle safety nut
SAI system removed - billet block off plates - black
O2 sensor eliminated
Al clutch cable adjuster -black
Al seat cowl mounting bolts - gray
Al hugger mounting bolts - gray
Al radiator cowl mounting bolts - gray
Al Front fender mounting bolts - grray
Al shark fin mounting bolts/nuts - black
Al front and rear reservoir mounting bolts - gray
Al under seat tray mounting bolts - black
Al rear panel mounting bolts - black
Denso IU01-27 plugs
ELF Moto 4XT-Tech 10w-50
Ordered
2012 Speed Triple bar - Silver
BOTM is BACK!
1050 throttle tube
DNA street filter
Custom Dyno tune
SS intake screen
CF heel guards
CF seat cowl
CF plate frame
R&G fork sliders
R&G bar end sliders
Denso IU01-27 plugs
Ordered
