121 - 123 of 123 Posts
Very nice!
Without a doubt, some 675R rotors with the black center would add to the look..
Not so sure i am feeling the stickers on the windscreen though, althought a nice daytona on the lower or fill in the lower slash indent with black would add to the scheme..
is this paint or plastidip?
Discussion starter · #123 ·
That moment when you're considering selling your bike and write up a parts list off of memory..
2006 Triumph Daytona
Bestem Carbon Fiber:
- Nose Fairing
- Infill Panels
- Chain Guard
- Heel Guards
OEM Triumph Carbon Fiber:
- Front Fender
- Rear Fender (Tire Hugger)
- Tail Fairing
SKUR Carbon Fiber:
- Triple Tree Cover
- Fuel Tank Cover
Custom Carbon Fiber:
- Tank Sliders
Brakes:
- Brembo M4 Monoblock Front Calipers
- Carbon Loraine SBK5 Brake Pads
- Brembo RCS19 Brake Master Cylinder
- CoreMoto Custom length Brake Lines (CF Appearance w/ polished ends)
- Custom 7075 Rear Brake Bracket
- Brembo P34 Rear Brake Caliper
- Brembo OE Brake Pads
- Galfer Wave Rear Rotor
- Sunstar Front brake rotors
Wheels / Tires:
- Powdercoated Red by Excalibur Powdercoating
- Fresh Dunlop Q3 Tires 180/55/17
- New Bearings and Seals
Suspension:
- Penske 8760-F11 Fully adjustable rear Shock
- Eibach 0500.225.0600 Spring
Body, Misc. & Protection:
- Wrinkle Red Powdercoated Subframe (By Excalibur)
- OEM Triumph Seat Cowl (Solo Seat)
- Engine Ice Performance coolant
- GB Racing Case Savers (Stator, Ignition and Clutch)
- R&G Front Axle Sliders
- R&G Rear Axle Sliders
- Woodcraft Frame Sliders
- Woodcraft bar end sliders (weighed)
- Zero Gravity Double Bubble Windscreen (Tinted)
- Jardine RT-1 Specific Fender Eliminator
- Integrated Rear Brake Light
- Flush mount LED Turn Signals
- 4300k HID Low and High Beam
- TechSpec Tank Grips
- OEM Trimph CF Appearing CF Tank Pad
Engine:
- Wrinkle Red Powdercoated Valve Cover (By Excalibur)
- Driven SAI Delete Plates
- BMC Air Filter
- Modified OEM Airbox w/ Reflectagold
- Air Intake Flapper Delete
- Custom Ceramic Coated Catless Header with EXUP Deleted (2" Pipe) wrapped with DEI Titanium
- Jardine RT-1 Exhaust (Ceramic Coated and Wrapped w/ CF Cap)
- Fresh Throttle Body Balance
- Regulator/Rectifier Recall Performed by Triumph
