41 - 60 of 1,021 Posts
So I ordered everything up and installed it today. Ill be posting pics of the installation in a little bit. I also have a 98 GSXR SRAD that I'm doing the same mod to. I'll let everyone know how they are doing when I post installation pics. Thanks for all the write ups on this!!!
I completed the FH008 change last night. I put it in the stock location on the 2009. Hooked it all up per instructions. I am reading 14.22 idle and 14.15 reving. I touched it and it is just warm. The stock one would fry an egg. Overall, I think a good preventative maintenance (I didn't have a problem with the stock one yet, but felt it a ticking time bomb).
On another note: When does the fan kick on? The fan used to kick on, but I have not heard it lately. I had 6 bars today and still no fan? Maybe not hot enough to kick on?
Anyone find a good price on ther r/r? My stock one died so I'm in need.
The ones on ebay for a 07 and newer CBR600RR are going for 70-100 bucks......prices are jacked up...got mine for 70.
Discussion starter · #51 ·
If you're willing to drill a hole in the mounting plate, you can pick up one of the FH010 units from a kawasaki for pretty cheap. I got mine off ebay the other day for $23 shipped! Works like a charm.
The flip side is the special connectors are more expensive (~$27 shipped) and collectively with the connectors, makes for a fairly large physical envelope.
Electrical gremlins are killing me
Great thread!
Here is a little background on a (possibly related) electrical problem. I have a 2007 Daytona 675. Last winter, I added HIDs (per another thread) and a 2Bros exhaust. I love the bike, but electrical gremlins are hounding me. The battery died last year, so after hemming around, I ordered a new battery and the bike was fine. When it was in the shop for a tune-up, I asked them to check the charging system, because it didn't seem to be charging the battery (I thought the alternator was fried.) The shop said it was fine and, after replacing the battery, it ran all summer with no problems.
In the winter, the bike was in storage, battery removed and on a tender. I took it out for the first ride in the spring and when I got home, my headlights were flickering (like little strobes...). After shutting it down, I tried to restart and it wouldn't. I pulled the battery and charged it. Next time out, started fine. Rode for 1/2 hour, parked, then wouldn't start. Got it boosted, drove 1/3 of the way home and bike died at intersection. Boosted again, drove 1/3 more of the way home and bike died in the middle of the street. Boosted again and made it home.
If this is happening, it seems to me that the battery is dead and the electrical system is not providing enough juice to run the bike. When an electrical system is fine, it seems that you should be able to yank the battery after starting and the bike should still run... I'm going to check tonight with the voltmeter, but does anyone think the rectifier / regulator replacement (and the enhanced charging approach) would help?
Any other thoughts on possible reasons for this?
Discussion starter · #53 ·
... When an electrical system is fine, it seems that you should be able to yank the battery after starting and the bike should still run...
That is incorrect - will not run with battery disconnected.
... I'm going to check tonight with the voltmeter, but does anyone think the rectifier / regulator replacement (and the enhanced charging approach) would help? ...
Only if the R/R is what is bad - work through the trouble-shooting guide in the initial post to affirmatively identify the problem
Thanks d'ecosse. I was fortunate that the bike was stalling out in the city ~3-5 miles from home (although that still seemed like an eternity).
I am planning to run some of the diagnostics tonight on the bike and see if I can find the source of the problem. (I recall testing the voltage across the battery last year when I had the problem and remember it being high 13s.)
Reading the thread on rectifier problems, seems like swapping out the R/R is not a bad idea regardless.
Question: In this mod, you suggest swapping out for a FH008 R/R and in another thread looping the R/R to the battery with short / heavy ga wire. When you ran the mod, did you relocate your R/R to avoid any of the heating issues? Wondering if this should be done as well.
Cheers
This may be a redundant question, but... for those who have swapped out the R/R (or even tested it), do you need to remove the gas tank to get access to it on the D675?
I can see it in front of the shock and I can access the bolts, but it doesn't look like I can see or reach the harness without lifting the tank. Thoughts?
I need to move on to the R/R and wiring tests. I checked the battery tonight and found that the voltage was 13V when the bike was not running, 12.4V w/ lights on but bike not running, and 12.1V when the bike was running. Cracking the throttle and increasing the rpm did not change the running voltage.
Fuses are fine.
Perhaps I'm not wording it properly, and the battery is needed to close a circuit (I'm no electrical engineer), but shouldn't the alternator run the bike fine and only be charging the battery during normal running? I was trying to say that I don't think it's normal for a battery to continue to discharge to power anything with a fully functioning electrical system.
Discussion starter · #57 ·
Once the engine is running, the charging system supplies ALL the power to the bike and also some current to charge the battery - the battery would normally supply zero current once generator is producing current.
The battery is however necessary to maintain operation - if disconnected, bike will die.
The reason bike 'sorta runs', even with a charging system problem, is that even with one phase down (whether stator &/or R/R) it will generate enough current from the remaining two to maintain running - however it will not be enough to supply all the running power, especially at low engine rpm. So the battery continues to discharge to point that it no longer supplies current to the system, and when the engine rpm drops, the generator cannot either, so it dies.
Then will not re-start because battery is already discharged.
Finally got my install done of the FH010. I drilled a hole in the mount bracket and put it back into the stock location running the wires toward the chain. Its tight, but it seems to fit just fine. My idle volts are now 14.2 and 5000 RPM's are 14.25. My HIDS seem to fire faster on the road and i dont get a "blinking" of the dash at idle with both lights on.
Great upgrade!!
help -14.5V
Hi guys, please could you help me?
Today I replaced the old original R/R (broken) with the FH008 on my Daytona 675. I followed the procedure described on first page. Now, If I don't connect + and - to the battery the R/R output is 14.5V. If I connect + and - to the battery the engine idle decrease, I can read -14.5V and after 2 o 3 seconds engine shut off!!!!!
Do you have any idea of what's happenning?
tks a lot
bye
Andrea
Would like some opinions and insight please. I followed the diagnostic tests per the first post and this is what I have. Please reference the pic following:
With Red terminal from multimeter to 3-prong harness and black terminal to 4-prong terminal:
P1 - B1: .880
P1 - B2: .880
P1 - R1: .502
P1 - R1: .502
P2 - B1: .921
P2 - B2: .921
P2 - R1: .512
P2 - R2: .512
P3 - B1: 1.
P3 - B2: 1.
P3 - R1: .515
P3 - R2: .515
Now with Black terminal to 3-prong and Red terminal to 4-prong:
P1 - B1: .880
P1 - B2: .880
P1 - R1: 1.
P1 - R2: 1.
P2 - B1: .920
P2 - B2: .920
P2 - R1: 1.
P2 - R2: 1.
P3 - B1: .456
P3 - B2: .456
P3 - R1: 1.
P3 - R2: 1.
Now correct me if I'm wrong but per the first post I didn't want to see a short. I don't see a short and "1." means there's an open circuit! My question here is does the open circuit mean my R/R is no good or am I doing something wrong here?
I continued with the diagnostics for the stator as follows:
I tested all three pins leading back to the stator in no particular sequence other than how they are numbered in pic. The readings were as follows:
1-2: 000
2-3: 000
3-1: 000
I then did the test from all three prongs just for piece of mind with the positive terminal of the multimeter and the negative terminal to the ground and all readings were "1." or open circuit.
I then turned the engine one and retested the harness in the same sequence as before using the AC volts check and all three readings were as follows:
At idle:
~25V
At 5k rpms:
~100V
I've opened my stator up and it doesn't look like anything is charred. Can someone let me know if I should be concerned of anything based on my pic. The glob of goo is solid and I thought it was going to feel like gelatin.
So after all that I have two questions. 1) Did I do the diagnostics on the R/R correctly since I read an open circuit vs a short 2) Does it sound like and look like my stator is good to go?
THANKS TO ALL THAT REPLY WITH ANY HELP! :notworthy:
