21 - 40 of 96 Posts
I don't remember how sensitive they were, but I don't recall having any trouble adjusting it whatsoever :D
Am I doing something wrong with the Tuneboy cable? I am borrowing a cable from a friend but it's not working for me or I'm just stupid and can't figure it out. I went to the Tuneboy site and downloaded all the software. I then burnt it all onto a disc and then installed it onto my laptop. After installing the software I went and installed the drivers by connecting the cable and going through the prompts as instructed in the PDF. After that I am lost. I can't use the Tunedit since I don't have key for my ECU but when I open Tuneboy I get nothing.
I attached some pics of some of the issues I am having with the cable and the port that I'm using. On the first two pics I have an option but don't know the correct one to choose. I've tried both and no luck! The third pic is just showing that it says "authentication failed. key required." The fourth pic I have no idea how to fix. There were some times that it read "...error code was 2" and I don't know what that meant either. The last pic is just showing what ports I have for the cable.
I have installed and unistalled the software and cable several times and used a different port each time but still no luck. Someone please help me and tell me what I'm doing wrong. Also, maybe I'm not doing something in the right order. After I install the software and the drivers what are the next steps in connecting the cable to the ECU, to turning the bike one, to firing her up? I may be doing something out of order there! PLEASE HELP!
EDIT: With all the times after I installed, I never got the cable LED to flash. I know that's something that was mentioned in the PDF and it never did.
When you say "used a different port each time but still no luck" did you mean trying all the USB sockets on the laptop.
The error on the second last pic shows some other driver is trying to use that port and the TB cable doesn't like to share.
In your last pic look up the dev list, right click on 'Ports (COM & LPT)' go into properties>port settings>advanced-click the pull down menu "COM port number' and raise the port number to 20 or higher if needed.
(this for XP which I run on my ancient laptop, vista/win 7 are similar though the wording is slightly different)
General procedure is, start laptop>plug cable from comp to bike> turn ign key on (wait for bike start up noises to finish) >run either TB or TE after a bit of red led activity you should see data
in the sensors panel if in TB.
Yeah I tried all the usb slots and still got nothing out of them. I'll give your fix a try and see how that goes. I am downloading from scratch again and seeing how it goes from there. Thanks for the advice.
It's been a while, but I remember having some similar issues the last time I tried to install the software. The solution in my case was to save the download to my desktop, then right click and install using the windows install wizard.
Just something simple to try, could have been a fluke but it worked for me. Good luck!
Well, after changing my COM port to 20 I am now getting an error saying "Can not open COM4. Error code 2." or something to that nature. It is error code 2 though. My laptop is a 32-bit so is that the issue?
I had a similar problem on my IBM/Lenovo laptop and this fixed it, I'm assuming your running XP
1)un-install tuneboy software, then go to program files or where ever you installed it to and delete all folders related.
2.) Do NOT have Tuneboy USB pluged in /right click my computer/properties/click the Hardware tab/ then device manager/ scroll down to USB contollers, click the little plus sign to expand/ uninstall anything Tuneboy.
3.) download Crap Cleaner http://www.piriform.com/ccleaner run the cleaner then click registry within CCleaner then scan for issues after it scan click fix all selected issues ,Back them up if you want they are invalid so I just delete all and no backup.... Restart your PC
4.) Now go here download latest FULL install and Tuneboy USB drivers http://www.tuneboy.com.au/tutorials_support.html#displayContentContainer
5.)After you download, Install the software FIRST....not the USB drivers... after you install and enter your KEY actually it still may be in there via the registry..... now plug in the USB cable see if it finds it if it asks you for the drivers open "USB driver download" extract the corresponding folder XP/98 or Vista to your desktop....... and direct the wizard to look in that folder for the USB drivers.....
6.) Restart your PC I usually do when I install new programs "crappy windows OS":cool: ...... plug usb into PC/Laptop,plug OBD connector to the bike, Turn on bike, open tune edit or tuneboy and see if your still having the problem.... Hope this helps bro.
32 bit is not your problem at all i run 32 bit.....Hope this helps, if it still persists it may be because you dont have a key..... but I thought you were still able to see codes an all that without a key.... you just cant upload tunes to the bike..... make sure comports are on set to USB in tuneboy...."cable type"... I still get error code 2 sometimes aswell I just restart laptop, plug in USB to laptop, plug in OBD to bike, turn ignition to on,start tuneboy.....no more error
just found this on tuneboys site.... IDK try what I said above first and if it still doesn't work then I believe the Key is your problem
"You will get the message "Authorization failed" in TuneBoy and "No Key for this ECU(nnnnnnnnnn)" in TuneEdit if you have entered the key incorrectly.
The key must be entered exactly as it appeared in the email response to your key request. If you have not requested the key please follow the "Getting started" section in the documentation or the "Getting started" tutorial on this web site."
I saw that this morning too on their site. I went ahead and emailed them to see if they can help. If not then I will just use the comp that my friend has. It's frustrating though because also thought that you could use the cable if you didn't need the function of loading tunes. I will try this all again tonight. Thanks all for the help.
Is visually looking at the adjuster screws good enough to know that I'm out of specs? The screw/spring is "longer" than the screw on the right.
EDIT: I tried what you mentioned earlier. Still didn't work but that's a nice little tool to have for cleaning things up! I don't have the key since it's my friends cable.
On my previous post, does it matter what option I choose for the cables for the first two pics? Thanks a million.
no I wouldnt try it visually... there is only 2 screws to adjust and you have to balance them to cyl #2.... besides chances are is that Cyl 3 will be out of spec and you will prolly only need to nudge them 1/4 to 1/2 turn to get them into spec....
I actiually had a PITA time getting them balanced for some reason.....to fix it what I did was screw them both all the way in, unscrewed them about half way out, even turns on the screw driver. started bike from there and slowly adjusted left and right screw till I got all 3 at 536/536/536, bliped throttle a couple times made sure it stayed @ those values
yes it does matter on cable did you try both?, I changed cable type while in tuneedit I think its #4 i thought it said USB cable in the drop down menu... not sure at the moment my laptop is at my father in-laws house..
EDIT:
I wouldnt use that found new hardware wizard, unless it cant find the cable after the Software install.... If it still doesn't find it, download the USB drivers from Tuneboy, extract the folder you need XP or Vista.... and when it asks for driver direct the wizard to that USB folder you just extracted on your desktop
Could this cause a weird noise almost like a knocking at idle? Im trying to figure out what this noise is on my bike. at 2k rpms my bike gets quiet pulls strong and at 2k rpms it like pops and goes smooth its really weird and seems electronically controlled and idk if its just the bike or if there is something wrong.
[nomedia="http://www.youtube.com/watch?v=59dbSlzy4ko"]YouTube- Daytona 675 Idle noise[/nomedia]
Heres the youtube link. You can hear it pop and then get smooth. any input is appreciated.
Bamboo13
Sorry, should have mentioned once you have changed the com port # as per my last post you should start TuneEdit, click options>properties and change the "serial port" number to match what you set in windows.
The cable should show up there as an option if its plugged in to the laptop select it click 'save' then close TE and try TB again.
...if that doesn't work
Restart TE & follow the procedure in the http://www.tuneboy.com.au/Support/TuneBoy_Documentation.zip for getting the ECU serial# especially selecting a correct tune for you bikes VIN range,
I know you don't need the serial for what you need to do but I have vague memories from when I first got the TuneBoy cable that the TuneBoy program refused to talk to the bike until I had established coms via the TE prog.
(you don't run both at the same time)
and don't touch the throttle balance screws without some feedback from TB you'll only make it worse.
Sweet! Thanks Baba! I am going through a how to of what I am doing and hopefully someone here can ID what I am doing wrong. Reason for me doing this is the PDF for Tuneboy shows different options then what I am getting on the program and maybe there is something I am missing. Will post ASAP and hopefully someone can help my 'tard ass!
I've got the serial number and was able to get it before but what do I do with that number? Do I need to input that somewhere? When I do see the screen displaying my ser. number I click OK and then close TE. I open TB and the Dash reads "connected to hardware" and then shortly after "authentication failed. key needed." Aaaaaah! Reading 0's on every page!
You've proved the TuneEdit prog can talk to the bike, getting the serial was just to confirm coms, you don't need it to run TuneBoy.
I can't remember if you mentioned what OS you are running but read this, http://tuneboy.com.au/forum/YaBB.pl?num=1250559998
Why TuneBoy isn't working for you has got me baffled,
are the battery volts ok? best to remove the headlight fuse as it can run the power down pretty quickly and have the bike on a trickle charger while doing all this, have you got the ignition on and kill switch in the run position.
You could try the new freeware prog TuneECU which can do everything TB & TE can
http://www.triumphrat.net/ecm-and-fi-tuning-help-tips-and-tricks/141608-tuneecu.html
You will have to uninstall the TuneBoy cable drivers and use the generic ones as described in DEcosse' thread at Triumphrat.net
That's what I thought about the serial number. I'm running XP 32bit. I'll try the fix-it on the link you provided. Thanks! Battery is good. I have HIDs so the batt drain is minimal. I've been able to have the bike on for awhile when I troubleshoot and still be able to fire it up right afterwards. Ignition is on and switch is in the run position.
Sequence:
Plug cable to laptop
Plug cable to ODBII
Open Tuneboy
Turn bike to "on"...let bike/program establish comm
Fire bike up for number readings on dash...
correct me if I'm in my steps. Thanks!
The cable worked on you friends bike?
Sequence:
Plug cable to laptop (confirm it is present by looking in Dev manager)
Open Tuneboy
Plug cable to ODBII (the led on the cable should pulse while it is handshaking with the bike, when coms are confirmed it should flash at high frequency)
Fire bike up for number readings on dash... (sensors screen, the map values are displayed in large font on the errors screen to make balancing easier)
Sequence:
Open Tuneboy
As far as I know and what he tells me the cable works fine. He's not using it on a D675 though. Could that be the factor? He's using it on a 955. I used the link you provided earlier with the troubleshooting and now I will try that sequence you told me just now. That may have been the problem since my sequence was different from yours. Thanks a ton Baba! :thumbup:
Just read through this thread and going to try and do this tomorrowish. You guys mention your numbers are around 600 but mine were around 780-800. Is this an issue and if so how do I correct it?
I'm running tune 20109 with the flapper open at 900rpm and the exup at 100% just below idle with a stock can.
Correct me if wrong but match them to the center throttle body right? That's the only one that's not adjustable.
21 - 40 of 96 Posts
