675 Parts Compatibility List
271K views 379 replies 191 participants last post by  scuncknuts
#1 · (Edited by Moderator)
Anyone have a 675 parts compatibility list they can share? I know things like a GSX-R brake lever and front sprocket fit. Trying to compile a complete list of parts from other Triumph or non-Triumph bikes that fit.
TIA.
UPDATE 7/18/09. Thanks to all who provided inputs and keep 'em coming including any updates/corrections to the existing list.
**DISCLAIMER: Nothing's perfect, use these suggestions at your own risk.
1. Oil Filter: BMW, 2007 CBR600RR, CBR1000RR
Comments: Direct fit.
K&N part number KN-204 fits almost every bike you can imagine including ours!
2. Fuel Pump: Yamaha R1 (2004+), Triumph Sprint 1050.
Comments: R1 fuel warning indicator is in a different place but it's fine for a track bike. Sprint 1050 pump connections identical to D675, but slightly different internal to the tank - fixing plate needs another notch filing in it to orientate the pump in the tank correctly and fuel sensor does not work.
3. Brake Lever: Suzuki GSX-R (2003+ GSX-R750, 2004+ GSX-R600, 2005+ GSX-R1000, 2008 GSX1300BK B-King)
4. Front Sprocket: Suzuki GSX-R 600 (01-07), Suzuki GSX-R 1000 (01-07), Suzuki GSXR 750 (00-07), Yamaha R6 (99-01), Yamaha R5/RD 350, ZX-10
5. Throttle Tube: Yamaha R1, Triumph Speed Triple, Triumph Sprint 1050
6. Fuel Tank: Triumph Speed Triple
7. Front Brake Pads: Yamaha R6 (2006+), Triumph Speed Triple (07-08), ZX-9R F1-2
Comments: Direct fit. ZX-9R F1-2 kawi part number 43082-1290 (has 3 grooves instead of 5).
8. Rear Brake Caliper: Yamaha R1, 03-05 Yamaha R6, 06-up Yamaha R6S
9. Mirrors: Ducati, Suzuki GSX-R, Triumph 955
Comments: Some mods needed. See threads below.
http://www.triumph675.net/forum/showthread.php?t=26130&highlight=ducati+mirrors
http://www.triumph675.net/forum/showthread.php?t=18199&highlight=gsxr
http://www.triumph675.net/forum/showthread.php?t=20287&highlight=gsxr
http://www.triumph675.net/forum/showthread.php?t=9045&highlight=mirrors
10. Clutch Perch & Lever: Yamaha R6 (2001)
Comments: Possibly other model years fit as well. Fine on race bike, may or may not be issue for street.
11. Steering Head Bearings: Yamaha R6 (99-01)
Comments: Probably compatible with other bikes as well.
12. Forks: Honda CBR 600RR (08), Kawasaki ZX6RR (03)
Comments: Honda 600RR is direct fit (may have to use RR axle). On Kawi forks, need to swap out the caliper blocks at the bottom of the forks. Caliper block is different to accommodate smaller axle - but fork tubes, caps and internals are the same.
13. Head Stock: Suzuki GSX-R1000 (05-06)
14. Headers: Triumph Speed Triple
15. Rear Swingarm Bobbins: Yamaha R6
Comments: Direct fit. 6mm bolts.
16. Footpegs: Honda CBR1000RR (04-08), Yamaha R1 (03)
Comments: Direct fit. Other model year Yamaha R1 may fit as well.
17. Front Brake Calipers: Triumph Speed Triple (07-08), Suzuki GSX-R1000, 750, and 600, 06 R6
Comments: Speed triple is direct fit. Suzuki calipers line up fine, but need to drill bolt holes out a little and add spacers to distance radially.
R6: Better Brakes - Finally! - Triumph675.Net Forums
18. Wheels: Yamaha R6 (03-07)
Comments: Mods required.
Trackday wheel options - Triumph675.Net Forums
19. Front Brake Master Cylinder Reservoir Assembly: Yamaha R1
Comments: A near perfect fit. R1 assembly is probably less expensive as well.
20. Clutch Lever: Triumph Speed Triple (04-07), Speed Four (05-06), Daytona 600/650 (04-05), 955i (04-06), Sprint ST/RS (04-07), Thruxton (04-07), Bonneville T100 (06-07), Tiger (07), Rocket III (04-07)
Comments: Direct fit. These are based on comparing Pazzo Lever part numbers, so there may be some variation for OEM or OEM direct replacements.
21. Rear Shock Mounts: Yamaha R6 (99-02)
Comments: Direct fit. Aluminum and about an 1/8 inch lower than OEM 675.
22. Fork Seals: 05 R6
23. Wheel Bearings and Seals: Suzuki, Honda
Comments: Suzuki rear wheel bearings (2 Req, SUZ P/N 08133-62047), Suzuki front wheel bearings (2 Req, SUZ P/N 08133-60047), Suzuki rear left outer wheel bearing - sprocket carrier (1 Req, SUZ P/N 09262-25061), Rear left oil seal - sprocket side (1 Req, SUZ P/N 09283-35028), Front wheel oil seals (2 Req, HONDA P/N 90753-074-003), Rear right oil seal - brake side (1 Req, HONDA P/N 91252-KZ4-003).
24. Crankshaft Position Sensor: Aprilia 450 RXV
Comments: Model year has not been determined as of yet.
A Nice Repair for Defective Crank Sensor! - Triumph675.Net Forums
#187 ·
For the fuel pump, if you break the plastic outlet pipe that the fuel line clips on you can seperate just that part. There is a few clips on it and if you spring them you can break them apart. Then use the Sprint 1050 piece and put that on. Everything lines up and works great.
I have pics if anyone is interested
#191 · (Edited)
i confirm that zx6r forks either 03-04 or 05-06[better because of the discbrakes diameter(03-04 had 280mm,05-06 had 300mm and 675 have 308mm..so u need smaller spacers for the calipers..) fit perfectly on a 675 triple tree!!
instead of getting the axle machined,u can buy a zx6 axle for $20 and change the wheel bearings as i did for maximum safety...the bearings that u need is a 42x25x12 size for the zx axle..prefer skf..and that's all!!good luck!!
sorry i forgot!!!!!!!!the distance between the tubes is longer on the zx6 so u will need to cut the axle about 10mm(i don't really remember..but u will see..) or else u won't be able to to screw the axle bolt till the end!!
#194 ·
I know that previous years fuel tanks fit on my '09, but have read that certain tubes, or connections are slightly out of equal.
Are these mismatched bits part of the tank itself, or the fuel pump?
If I purchase an '06-'08 tank for my bike, can I safely assume my '09 fuel pump and gas cap will fit?
Thanks
#196 ·
Anyone know if the Daytona 600/650 front discs will fit the 675 ('07)???
thx
#198 ·
Can anyone confirm or deny that the lower fairings are the same across all years?
I need a right side faring, and they all look the same (meaning the cut outs are the same, same shape etc) but I don't know if the turn signals line up, or if the R&R relocation (on the right lower fairing) works on the older fairings. Do they join up to the 09+ upper fairing properly?
#200 ·
Hey MacBandit...
Just looked at 06Triumph675's set of rotors in the classifieds and compared them to a set from the D6 on ebay and they both have 5 mount holes and 8 of the expansion, (semi-floater) rings.
Could be worth a look n' see as a cheap replacement.
Different colours and cosmetics but maybe.... just maybe...
#205 ·
Hi :)
sorry for not reading al the 21 pages..... ;-)
I'm thinking to change the brake calibers on my 06 trackdaybike, to some monoblock calibers..
does the newest d675 calibers fit the old one ?
..or perhaps the speed triple calibers fit ?
..i see that the GSXR fits, with a litlle mods (which year's by the way)
#212 ·
D675 Fairings
I see that Aviator asked this before but I didn't see a response. Will 07 plastics fit on a 10 bike? Would the tabs line up if I used an 07 plastic on the left with a 10 on the right??? What about the nose, could I put an 07 nose on a 10 bike if I had both left and right from an 07??? Could i use an 07 nose with 10 fairings...
you get the picture... thanks in advance for any words of wisdom...
Thanks
-Brian
#213 ·
Thanks
-Brian
Yes, yes and yes. For the nose though you also need matching year headlights & windscreen
#215 · (Edited)
The 675 and Daytona 600/650 front brake rotors are NOT compatible. They have the same diameter and bolt pattern but the 675 has cut outs which the rotors sit within, helping to hold it in place. The 600 relies solely on the bolts.
The front axle spacers are the same (on one side) - same part numbers. The 600 has a stepped spacer the appears the same as the other when fitted but sits within the bearing unit.
The sprocket side rear spacer is also the same - again, same part numbers and description.
The caliper side rear axle side spacer is DIFFERENT. The 675 is 3.5mm longer between the shank and the beginning of the schamfer (6mm V 2.5mm), making it 3.5mm shorter overall. The shank is the same length, so I would assume the recess to be the same.
The rear axle is DIFFERENT. The 675 is 13mm shorter.
Wazza
#216 ·
Not sure if it has been discussed before but you can use a Vesrah SF-4007 oil filter ($8), its identical to the Triumph OEM one and about $5 cheaper then Triumphs OEM.
#220 ·
According to K&N site, the KN-204 filter fits almost any bike you can think made in the last 10+ years.
http://www.knfilters.com/search/applications.aspx?Prod=KN-204
So there must be something in common with all bikes, so just find whatever fits those and you should be good.
As for me spending $14.95 on a K&N is fine.
#221 ·
