675 Parts Compatibility List
271K views 379 replies 191 participants last post by  scuncknuts
#1 · (Edited by Moderator)
Anyone have a 675 parts compatibility list they can share? I know things like a GSX-R brake lever and front sprocket fit. Trying to compile a complete list of parts from other Triumph or non-Triumph bikes that fit.
TIA.
UPDATE 7/18/09. Thanks to all who provided inputs and keep 'em coming including any updates/corrections to the existing list.
**DISCLAIMER: Nothing's perfect, use these suggestions at your own risk.
1. Oil Filter: BMW, 2007 CBR600RR, CBR1000RR
Comments: Direct fit.
K&N part number KN-204 fits almost every bike you can imagine including ours!
2. Fuel Pump: Yamaha R1 (2004+), Triumph Sprint 1050.
Comments: R1 fuel warning indicator is in a different place but it's fine for a track bike. Sprint 1050 pump connections identical to D675, but slightly different internal to the tank - fixing plate needs another notch filing in it to orientate the pump in the tank correctly and fuel sensor does not work.
3. Brake Lever: Suzuki GSX-R (2003+ GSX-R750, 2004+ GSX-R600, 2005+ GSX-R1000, 2008 GSX1300BK B-King)
4. Front Sprocket: Suzuki GSX-R 600 (01-07), Suzuki GSX-R 1000 (01-07), Suzuki GSXR 750 (00-07), Yamaha R6 (99-01), Yamaha R5/RD 350, ZX-10
5. Throttle Tube: Yamaha R1, Triumph Speed Triple, Triumph Sprint 1050
6. Fuel Tank: Triumph Speed Triple
7. Front Brake Pads: Yamaha R6 (2006+), Triumph Speed Triple (07-08), ZX-9R F1-2
Comments: Direct fit. ZX-9R F1-2 kawi part number 43082-1290 (has 3 grooves instead of 5).
8. Rear Brake Caliper: Yamaha R1, 03-05 Yamaha R6, 06-up Yamaha R6S
9. Mirrors: Ducati, Suzuki GSX-R, Triumph 955
Comments: Some mods needed. See threads below.
http://www.triumph675.net/forum/showthread.php?t=26130&highlight=ducati+mirrors
http://www.triumph675.net/forum/showthread.php?t=18199&highlight=gsxr
http://www.triumph675.net/forum/showthread.php?t=20287&highlight=gsxr
http://www.triumph675.net/forum/showthread.php?t=9045&highlight=mirrors
10. Clutch Perch & Lever: Yamaha R6 (2001)
Comments: Possibly other model years fit as well. Fine on race bike, may or may not be issue for street.
11. Steering Head Bearings: Yamaha R6 (99-01)
Comments: Probably compatible with other bikes as well.
12. Forks: Honda CBR 600RR (08), Kawasaki ZX6RR (03)
Comments: Honda 600RR is direct fit (may have to use RR axle). On Kawi forks, need to swap out the caliper blocks at the bottom of the forks. Caliper block is different to accommodate smaller axle - but fork tubes, caps and internals are the same.
13. Head Stock: Suzuki GSX-R1000 (05-06)
14. Headers: Triumph Speed Triple
15. Rear Swingarm Bobbins: Yamaha R6
Comments: Direct fit. 6mm bolts.
16. Footpegs: Honda CBR1000RR (04-08), Yamaha R1 (03)
Comments: Direct fit. Other model year Yamaha R1 may fit as well.
17. Front Brake Calipers: Triumph Speed Triple (07-08), Suzuki GSX-R1000, 750, and 600, 06 R6
Comments: Speed triple is direct fit. Suzuki calipers line up fine, but need to drill bolt holes out a little and add spacers to distance radially.
R6: Better Brakes - Finally! - Triumph675.Net Forums
18. Wheels: Yamaha R6 (03-07)
Comments: Mods required.
Trackday wheel options - Triumph675.Net Forums
19. Front Brake Master Cylinder Reservoir Assembly: Yamaha R1
Comments: A near perfect fit. R1 assembly is probably less expensive as well.
20. Clutch Lever: Triumph Speed Triple (04-07), Speed Four (05-06), Daytona 600/650 (04-05), 955i (04-06), Sprint ST/RS (04-07), Thruxton (04-07), Bonneville T100 (06-07), Tiger (07), Rocket III (04-07)
Comments: Direct fit. These are based on comparing Pazzo Lever part numbers, so there may be some variation for OEM or OEM direct replacements.
21. Rear Shock Mounts: Yamaha R6 (99-02)
Comments: Direct fit. Aluminum and about an 1/8 inch lower than OEM 675.
22. Fork Seals: 05 R6
23. Wheel Bearings and Seals: Suzuki, Honda
Comments: Suzuki rear wheel bearings (2 Req, SUZ P/N 08133-62047), Suzuki front wheel bearings (2 Req, SUZ P/N 08133-60047), Suzuki rear left outer wheel bearing - sprocket carrier (1 Req, SUZ P/N 09262-25061), Rear left oil seal - sprocket side (1 Req, SUZ P/N 09283-35028), Front wheel oil seals (2 Req, HONDA P/N 90753-074-003), Rear right oil seal - brake side (1 Req, HONDA P/N 91252-KZ4-003).
24. Crankshaft Position Sensor: Aprilia 450 RXV
Comments: Model year has not been determined as of yet.
A Nice Repair for Defective Crank Sensor! - Triumph675.Net Forums
#109 ·
675 shock
HI. I NEED A DAYTONA 675 SHOCK. I DISASEMBLE MINE IN ORDER TO SWAB THE SPRING TO INSTALL A RACE TECH PROPER RATED ONE BUT REALIZED THAT THE SHOCK PRELOAD THREAD AND PRELOAD ADJUSTMENT COLLARS ARE DAMEGED TOO. SO IF ANYONE OF YOU GUYS HAVE THE SHOCK LET ME KNOW HOW MUCH SHIPPED TO ZIP 00728 BY PRIORITY MAIL.Paypal avaliable.thanks
#110 ·
Ouch... my ears are bleeding :topsy:
#115 ·
#116 ·
Has anyone on the forum actually tried the CBR forks on a Triumph? Considering the shortage of Daytona front ends vs Honda CBR front ends I'm seriously considering trying the CBR forks on a Street Triple but just wanted to here from anyone that's attempted or been successful in doing this change over.
thanks
#119 ·
The Bosch 72161 is a direct fit for BMW motorcycles so it can be assumed that it will fit the Triumph as well. I've recently ordered a few to have on hand for my customers and friends BMWs I work on so I'll post back in the spring when I change my oil next time.
I've decided to go this route despite my fondness of using OEM oil filter (warranty and guaranty reasons) after reading this.
http://motorcycleinfo.calsci.com/Filters.html#OilFilters
I for one am not going to shine off Puralator's warning because I know how critical oil flow/volume is as well as pressure and if the the PureOne reduces flow due to it's tighter matrix I think it would be best to heed Puralator's warning.
#121 ·
Going off the cross-reference charts it doesn't appear this is the correct filter, instead the Bosch 3323 would be. The 72161 may indeed fit, it just isn't the same size filter.
#141 ·
+23049249 im about to order a set of aftermarket 03 r1 rearsets and would like to know if these are going to work????!!!!
#129 · (Edited)
Just received a set of gloss black forks off an 08' CBR 600rr to try and replace my bent gold ones on my 09' 675. The forum says they are compatible but from looking at them now the CBR forks seem like they will put my calipers in a place that is not so ideal. But will let ya know soon.
also the mounting points on the cbr forks for the front fender is completely different..
the diameter of the cbr forks measures too wide for the lower triple clamp and I don't want to try and force anything and/or scratch them.
again, who has actually done this swap? as I am quickly rethinking this idea.
help
