181 - 200 of 380 Posts
Has anyone successfully installed the integrated mirrors from either a Ducati 848/1098, 08+ Honda CBR1000RR or 2006+ Suzuki GSX-R600/750/1000? If so do you have a photo? I'd really like to try it but don't know if it would work and be a neat fit.
i can steal the ones off my brothers gixxer this week its sitting in my garage and check for ya ..he never rides anyways
For the fuel pump, if you break the plastic outlet pipe that the fuel line clips on you can seperate just that part. There is a few clips on it and if you spring them you can break them apart. Then use the Sprint 1050 piece and put that on. Everything lines up and works great.
I have pics if anyone is interested
i confirm that zx6r forks either 03-04 or 05-06[better because of the discbrakes diameter(03-04 had 280mm,05-06 had 300mm and 675 have 308mm..so u need smaller spacers for the calipers..) fit perfectly on a 675 triple tree!!
instead of getting the axle machined,u can buy a zx6 axle for $20 and change the wheel bearings as i did for maximum safety...the bearings that u need is a 42x25x12 size for the zx axle..prefer skf..and that's all!!good luck!!
sorry i forgot!!!!!!!!the distance between the tubes is longer on the zx6 so u will need to cut the axle about 10mm(i don't really remember..but u will see..) or else u won't be able to to screw the axle bolt till the end!!
I know that previous years fuel tanks fit on my '09, but have read that certain tubes, or connections are slightly out of equal.
Are these mismatched bits part of the tank itself, or the fuel pump?
If I purchase an '06-'08 tank for my bike, can I safely assume my '09 fuel pump and gas cap will fit?
Thanks
Anyone know if the Daytona 600/650 front discs will fit the 675 ('07)???
thx
Can anyone confirm or deny that the lower fairings are the same across all years?
I need a right side faring, and they all look the same (meaning the cut outs are the same, same shape etc) but I don't know if the turn signals line up, or if the R&R relocation (on the right lower fairing) works on the older fairings. Do they join up to the 09+ upper fairing properly?
Hey MacBandit...
Just looked at 06Triumph675's set of rotors in the classifieds and compared them to a set from the D6 on ebay and they both have 5 mount holes and 8 of the expansion, (semi-floater) rings.
Could be worth a look n' see as a cheap replacement.
Different colours and cosmetics but maybe.... just maybe...
