Obviously the owners manual says 89 or higher. Is there any need to put the expensive-ass 93 in , or even worse, the 110 octane Turbo Blue race gas?
Total BS :laugh:I know that if I ever put anything less than 93 in my Acura RSX Type-S it knocks like crazy. The same thing will happen if you run less than 89 in the 675.
We've been waiting for you guys for agesOne of these days we will all be riding on the same side of the road and talking the same language :rofl2:
Every motorcycle forum goes through the "Which Octane Should I Use" thread periodically, and I feel the need to clear up a few mysteries and myths. Observe:
1) As stated above, octane is figured differently in the States as opposed to the rest of the world.
2) Octane in a measure of the fuel's resistance to ingniting under compression, all other things being equal. Changes in altitude, humidity, and temperature can affect this. Igniting under compression causes pinging, which is BAD.
3) High performance engines usually have higher compression ratios, requiring higher octanes.
4) Octane is NOT a measure of power delivery, as the gas stations would have you believe. See #2.
5) Higher octane fuels also tend to burn slightly slower, which can rob a high-revving engine of power.
In summary: Use the lowest octane fuel you can that doesn't cause your engine to ping. Higher octane fuel is simply a waste of money. Following the recommendation of the manufacturer will not lead you astray.
