I installed the rest of my frame sliders from motovation. Got the front, rear and engine ones done... and did the rim tape yesterday
RIGHT? At least yours was ONLY 30 mins. Presumably you didn't drop a nut into the bike's frame like I did! :laugh:Finished putting my Manta wind screen on. 30 min. bull s#$t.
Thanks Sp00ky, the cables appear to be all fine but full left lock is just touching my my instrument panel, I was going to check your settings and compare notes next time we catch up, weather is looking good for tomorrow so may see you then.Hey Rob, looking good mate.
Don't forget to check for tank / thumb adequate clearance on full lock both sides.
Also, make sure that all your cables don't get too tight on full lock, or that any part of the switch gear doesn't hit the tank.
Just use the stock instrument cover on the back of the clocks...
I had to move my master cylinder main brake line to clear the instrument panel on full lock, thereby getting some air in the lines.
No problemo, thinks I .... I will just bleed the front brakes again to get rid of the bubbles.
Well, I stuffed one of the soft allen head screws on the master cylinder top and it took some real buggerising around to get that fracker out.
I finally won by using a soft head hammer and a pin punch to shock the wrecked screw loose. Thanks to Chris at Northside for the replacement screws.
All is now well.
Lots of Imperial Stormtroopers up there today, I saw four different cars, so be careful!
There was a new one, completely unmarked, colour was greenish / grey.
They are sure to all be out tomorrow, looking for you.. heheheh...
S.
