1,001 - 1,020 of 1,021 Posts
Can you help me to confirm whether my R/R is the new or old version? I have no charging now and try to find the reason. From what I can say it could be old, recalled version but I need to be sure. Bike is Street Triple 2008. Thanks!
Thank you for answer. So it seems that for 10 years (but less than 10k miles) nobody took care of the r/r. I'm sure it's dead. (after charging battery it shows 12.8V, and drops to 12.4V with engine running). Let's see what will Triumph dealer do with this... Best way for me will be if they could send me a new one, as the nearest dealer is about 100 miles far. Do you know if they accept installing new r/r by the owner? I take care of maintenance of my bike in general.
In that case your best bet is to just buy one and do it yourself. I don’t know about your country but here they want a dealer to verify the part and install it or they don’t pay for warranty. This covers their legal lia unities under a warranty campaign.
Power loss
Hello to you all.
I noticed that I don't have the correct voltage at the battery.
So I changed the stator, battery and rectifier.
It seem the the stator was broken.
Everething went good, bike starts , enouf voltage.
Now after 2 weeks ,the bike wont start after 1 night outside. Batery was empty.
Recharged again and had no problem all day. He now stands still for a few days, then looks again to see if the battery is empty again.
Is there a know problem with the street that pul the battery down?
https://imagizer.imageshack.com/img923/6685/7aiGYN.jpg
https://imagizer.imageshack.com/img921/4114/cJiCCT.jpg
https://imagizer.imageshack.com/img924/6420/cYvRtq.jpg
Thanks Ed
Hello to you all.
Thanks Ed
Get the battery Load tested, it should not drop below 10v with a load. These motorcycle batteries are weak, they can't handle too many deep cycles like car batteries.
I also would like to know what your charging voltage is with your bike at idle.
Worse case scenerio is you have a parasitic draw. I'm really hope someone just turned the key too far back and left the park lights on lol!
These are the results.
day 1 ;battery :13,1V , with ignition on 11,94 V , when starting +-8 a 9 V , stationair 14,22 V
day 7 ;battery :12,65V, with ignition on 11,80 V, bike wont start, starter goes around, but I qiut to soon.
put it on the charger again, 13,5 v, ignition on 12,22 V when starting 9,5 V stationair 14,3 V
What is between the battery and the ignition key, thats pull the battery down?
Has sombody a electric schedule?
Thanks
ed
So this is whats going on, I've read this thread, about 2 or 3 times, trying my best to understand it and I deferentially ready to tackle to the task. The only issue im having right now is sourcing the correct R/R if anyone is able to help me that would be great.
Stator wire order: Based on the voltage outputs described in the original post, and a response to a post by Hokie early in the thread, it sounds like the order of the stator wires being connected to the R/R doesn't matter? Would just like to confirm this before I start throwing amps through the bike.
The reason I ask is because I found a used, unburnt OEM stator & CPS (with good impedance). The stator connector had melted down (as per D675 normal), and the owner had snipped and tossed it. The wire insulation is identical; no stripes to identify which is which.
Please help me diagnose what is going on with my Street Triple!!
Had an accident, damaged the alternator cover, got a new one put it back together and realized it isn't charging.
Tests run as follows:
Voltage ignition off, 12.8v, bike running 12.0v
Measured between all 3 pins from alternator plug, reading approx. 0.03 ohms across all options
Measured from ground to all 3 pins from the alternator wire, showing short*
* due to this determined that alternator was shot, fitted a new one, exactly the same problem and no juice coming out from alternator.
Anyone any idea what is going on here? Could it be damage to the rotor??
Hoping someone can help me out here… so I have a 2011 675 with the original stator and RR. They both function normally, I did the stator tests and it’s putting out good voltage and the resistance values look good, I’m seeing 14.5 ish volts at the battery on idle and with the fan running and both headlights on, it’ll drop to 14.05 on idle.
The stator puts out like 70 ish volts at 5k ish rpm in all three phases while hot so I think it’s good.
The issue is this:
I replaced the oem shunt regulator for a sh847 and the triumph link lead to connect it, and I’m seeing 14.5 volts on idle, but once the bike is hot, the engine stutters badly and doesn’t want to run, but this is only with the sh847! The bike runs normally with the stock RR. I’m thinking maybe I should replace the fan relay if it’s getting corroded and has too much resistance, it might upset the 847, since it seems to run okay when cold, but otherwise I’m at a loss.
Please help!
+1 for me.
Have the same issue on my 2014 only when the radiator fan is on the idle is very erratic and the bike stall occasionally. I have a mosfet RR.
