Street triple 675 EXUP valve removal
92 views 3 replies 3 participants last post by  Robbi18
Hi All. So, I want to remove the exup valve on my street triple (2016).
I want to remove the whole component and use a plug&play device to eliminate the fault light. Is this possible? I've only ever done this on Jap bikes, it was pretty easy.
My questions are 1. Does such a device exist for the street triple?
2. Do I need to blank off the valve opening or can I remove the flap?
3. Will the bike run ok without any mapping?
I have an arrow can, with the huge muffler built in. I may change the whole system down the line if I can find a good deal. Appreciate any help 👍
#2 ·
1. Yes. I have a Visi-Tec one I ended up not using if you can't find one closer to home.
2. You can't remove the flap unless you change the header. You can lock it open though. Search for "My EXup Valve Adventure" for my experience doing this.
3. No tuning is required.
