PC map and Triumph tune
2K views 3 replies 4 participants last post by  Ditch Doctor
2013 Daytona with Trm8tr's header and M4 can. I had the ECU remapped with Triumph tune when I put on the M4 (it worked very well). I've ordered the PCV. It will be a while until I have time/cash to get a custom tune. In the interim, I'm going to install the Hindle full system map from Dynojet's website. Anybody know if this will work with the Triumph tune installed?
Or am I overthinking this?
#2 ·
I have a 13 Daytona also and pretty much have the same setup as you. I'm waiting for SAI block off plates to get a accurate tune. I downloaded a map from pcv but they do not have a lot of choices. The map works fine but not perfect, I get popping on deceleration sometimes. Custom tune here in California is about $300 to $400.
#3 ·
The tunes on their site for our bike are pretty shit. I was way lean up top with it. Its better then the stock map but its far from perfect, I would go easy with it until you get it properly tuned as I was around 15-16:1 at WOT.
SAI turns off after the bike gets up to temperature. It helps heat up a cold cat so it becomes efficient more quickly. Once the bike is warm it will not effect the tune, and you shouldnt be tuning a cold engine. Popping on decel is completely normal in moderation, a bad exhaust seal could cause some popping but its really not an issue at all.
#4 ·
I have a custom PCV tune for a 13 with TRMN8TR header, arrow slip on, servo delete, SAI block off, 90 grade 100% fuel if you want to check it out
pm me and i will e-mail the file to you
it is very reduced all across the rpm range because i had the dealer put the full arrow map on the bike and it was running rich for just the slip on set up i had.
