Oil Pressure Light and Switch Problem + Testing Oil Pressure
2 reading
35K views 73 replies 23 participants last post by  RideOki
Hi I have a 09 Street R. Exactly the same,I had to replace the generator. Otherwise my problem is the same. Just before it happened the bike felt flat and when I pulled up it revved at about 3k before I shut it down. Now it runs normally but the gen is not producing full charge and the oil light comes on at low revs. The radiator is full of muck from country roads and winter riding so over heating is a possible as well.
675R Oil Light
Same issue oil light on at tick over, changed the switch and stripped the motor to check the pump all well within spec. There was an early mention of running a Rocket 3 oil pressure relief valve, which is reputed to have a higher setting. Has anybody tried this. I believe the std pressure switch activates at 6 psi, somebody said the value they are measuring at tick over was 4psi, is there a more suitable switch available. I noted that the same switch is used across the triumph range but the problem only seems to affect street and Daytona bikes.
Any body got any updates?
