check engine light
1.2K views 1 reply 2 participants last post by  mspiegle
I know there’s a few posts about it in the main section but im curios if anyone in aus has had the sticky exhaust valve problem. My light came on the other day, took it to the dealer and they said it isn’t a big deal its mainly just for noise and emissions and it can wait till first service as im only 200k’s out. It just piss’s me off to see the light on all the time and makes me wonder if anything else will go wrong. anyone else seen any problems yet?
#2 ·
Yup. the adjustments for mine kept coming loose. They used locktite to hold the adjuster nuts in place. It would be very easy for you to adjust yourself. I believe the spec is about 10-15mm of play in the cable. Use locktite to ensure that the adjustment doesn't change. I've been CEL free for the past couple weeks (normally i'd get it once every other day)
