Hi all,
First post, looking for some assistance.
I'm looking for a wiring diagram for the ABS system for my 2014 street triple R.
Also, if anyone has one, I'd like to see if anyone has a photo of their str with the seat off, specifically showing the area of the relays by the battery.
When I bought my STR last year, I didn't like the idea of ABS, and requested that the dealer disable it. They told me they would be able to shut the system off with their software. Since then, I have decided to give it a shot, and want to enable it to give it a whirl. The dealer is fairly far away, so I began to research ways to turn it back on myself. After a bit of research, I'm fairly confident they were not being honest when they told me they could disable it using software, and instead disabled it by other means. Using dealertool, I see I have a currently present fault for the front wheel speed sensor that can not clear. I traced the sensor to the connector at the harness and it appears to be plugged in. The ABS fuse is ok.
So long story short, I'm trying to get a better idea of the system so I can trace down what has been done. I have one open spot in the relay panel where a relay could be, but is not, but I'm doubtful that a relay would be used in the front sensor circuit, but I am curious about that open spot, as I was able to find one picture off google that showed what appered to be a 14 str and there was a relay in that spot.
I appreciate any help that can be given.
-Jon
-Jon
