21 - 40 of 42 Posts
Looks like a good time!
Well I'm back from 3 days testing in Spain and as mentioned earlier in the thread I did a comparison between the 180 and 190 rear.
I started the sessions with the Dunlop GP212 with a 190 rear. Day one was all about running the bike in and learning the track so I didn't go too fast but I did notice the bike was rock steady but turned way too slow. On turn 3 & 4 a right left flick many a time I thought I was going to run on into the gravel as I was fighting to get the bike over from right to left. We dropped the forks through the yokes by another 10mm and softened the high and low speed comp at the rear. This helped massively and now the bike was heading in the right direction and changing lines quickly. Bike held a good line on the fast sweeper but was now nervous down the back straight and shacking it un-checked head as I changed up into 5th. Didn't need a damper just yet. Grip was fantastic and getting the power down never a problem.
So we then changed to a 180 rear. Bike was slower to turn and now leaving longer black lines out of the corners, but lap times where quicker! I dropped the forks another 4mm and got the steering as quick as I wanted it. The bike was easier to flick left/right and drove better with the smaller tyre. Back to the 190 on the same settings I was nearly on the dirt a few times as I over steered.
Verdict time. The 190 gripped far better than the 180 but speed suffered probably down to the mass of the tyre and the extra grip creating more drag. The 180 felt so much better and the bike was easier to change direction. I preferred to slide the bike out of the corners to help tighten up the exit and i think thats why my times on the 180 where quicker. The Cartegena is all about tight turns and short point and shoot sections. Far better suited to the 180. I will certainly be using a 180 on tight tracks and a 190 on tracks with fast sweepers. But if I had to choose one tyre size it would be 180.
great review
I have an 07 d675 running stock forks plus 08 cbr600rr rearshock with 180 rear supercorsas, and I'm oversteering it.
thinking about tweak my steering by sinking the forks under the triple clamp; right now i'm 2mm above it and feels twitchy.
great write up, sid.:thumbup:
great review
track or street?
I run my 2010 with Ohlins internals -4 into the triple. We all have different styles. This works for me.
Discussion starter · #27 ·
That's exactly the feedback that I was looking into. I would like to stick with the 180 but since the rest of my team are running Dunlops this year in gonna have to switch to the Dunlop slicks and put a 190 on my bike. But as long as I get the suspension set up I should be alright, correct?
great review
Details on running the 600rr rear shock?
Anything is better than the stock shock on the first Gen. :smug:
Yeah, I have a 550lb spring on the stock gen 1 rear shock and it was an improvement over stock but the 600RR unit can be picked up for like $50 on ebay. Has me interested now...
I see that the 600RR and 675 rear shock length is 293mm eye-to-eye. I also see that the 600RR rear spring is 11kg/mm (615lb) and the 675 rear spring is 12.6kg/mm (705lb) stock.
Yes! I run the dunlop slicks as well as a few other members. Best tire I have been on.. They freakin rock!
Have you tried the UK version in the 195/65/17 & 125/75/17 size? After I burn through this set of Supercorsa SC's I have for my next trackday I am considering the D211GP or NTEC slicks.
Yes.. I have run the 190 UK ntec Dots, 195 slicks and US 200 slicks.. I have also used moto 2 slicks.
Ask BMO on this board as well. I made him make the switch and he has thanked me numerous times...
I can't tell a difference between the 195 and 200.
I'm over a second a lap faster on a 190 Pirelli slick than a 180 Pirelli slick at Phillip Island. Ran them back to back on the same day with the same suspension settings and was consistently faster on the 190.
Sent from my Motorcycle iPhone app
21 - 40 of 42 Posts
