Well, i only have a few more days left this year, but I'd like to get this damn overheating issue straightened out. Took the bike to one shop for mapping, but a new map didn't help that issue.
Basically, the overflow bottle boils over after one hard session. A little better with overcast skys, but still overheats. When I come into the pits, it's about 2 bars from the top, and I can see the water boiling over to the overflow bottom. I cut the engine off before I come to a stop, but it doesn't help much.
On the track, I don't think I've seen it go past 3 bars to the end. It clearly is something that happens on the cool down lap (ironic).
Not much to the cooling system, no thermostat, no fan, full kit race motor. Thinking it may be running lean, I did richen up the lower throttle position map on the PC3, which did help a bit. Had a custom map made, but they didn't touch the zero to 2% throttle side. Go figure. No shortage of power, very satisfied in that department. Running Sunoco 100 octane race fuel if that matters.
I got a new radiator cap on the way, and I plan on relocating the overflow bottle to somewhere cooler. Right now, it's behind the radiator. Can't think of much more to do, maybe try to re-wire a fan back on?
Water has been flushed several times, hoses burped with the radiator cap and left screw unpluged. I still think air is getting in there somewhere, cause my Aprilia used to have a similar problem. The 250 had a few bleed screws in the block, I didn't see anything like that on the 675.
Can't believe they haven't flaged me at the track yet, it's pretty obvious what's happening.
Any ideas are appreciated.
