Looks like I waited too long to buy A1241041. If anyone has a manual idle adjust they'd sell, shoot me a pm.
For anyone else in a similar boat this advice by Fastway worked very well. Just needed to get a m5x.8 bolt that was long enough that I could adjust it through the frame on the right side with a elbow jointed attachment for my 8mm socket. Cost me all of about 2 dollars to get the bolt, a couple nuts to serve as a sort of washer and a spring.You can make up your own, just pick up a long screw (with same thread pitch and diameter), flat washer and a spring for tension. Made several up when the kit ones went obsolete
You got pics? I'm considering buying the manual adjuster, but if it's really that easy I may just do this....where'd you get the spring too?For anyone else in a similar boat this advice by Fastway worked very well. Just needed to get a m5x.8 bolt that was long enough that I could adjust it through the frame on the right side with a elbow jointed attachment for my 8mm socket. Cost me all of about 2 dollars to get the bolt, a couple nuts to serve as a sort of washer and a spring.
Sent you a pm.You got pics? I'm considering buying the manual adjuster, but if it's really that easy I may just do this....where'd you get the spring too?
Can I also have that info?Sent you a pm.
I'm phicurious why you wont just share this info in the thread for the whole community?Can I also have that info?
This is relevant to my interests as well. Tried looking for the official one and have come up empty. Thankfully Google came up with your WTB post, which I didn't expect to actually have a cheap DIY solution! :grin2:Laziness and I started this thread as a WTB. I'm happy to post my notes in a "how to" if there's an interest.
