I've never hear if it could. However I thought the Triumph TRACS software was free.
Not as far as I can tell. Anyone got a link?I've never hear if it could. However I thought the Triumph TRACS software was free.
I've tried restarting it. I think the previous owner said the check engine light was from the exhaust valve removal. If I'm reading the blink code correctly, it seems to be "MAP sensor pipe disconnected". I believe the MAP sensor was relocated to the intake air duct. I don't know what the MAP sensor "pipe" is.It should communicate with TnueECU. Try switching the bike off and on and restarting TuneECU. Also you shouldn't have a CEL up for the EXUP if you have plugged in the Race ECU as these ECU's don't recognise things such as EXUP valves and intake flappers etc. I'l take a wild guess and say that you have a CEL up because the Race ECU is not compatible with your dash.
Your MAP Sensor should be attached externally to the rear left hand side of your airbox. It is supposed to have a hose attached to the sensor that runs down to a 3-way junction which has 3 hoses leading to your throttle bodies. Don't know why this sensor would be relocated to the intake snorkel. There is a sensor the same as MAP sensor on the intake snorkel but this sensor is the barometric pressure sensor.I've tried restarting it. I think the previous owner said the check engine light was from the exhaust valve removal. If I'm reading the blink code correctly, it seems to be "MAP sensor pipe disconnected". I believe the MAP sensor was relocated to the intake air duct. I don't know what the MAP sensor "pipe" is.
You're right, it is the barometric pressure sensor. They look the same to me, and it must have been relocated because I had to drill the holes to mount it on my new snorkel.Your MAP Sensor should be attached externally to the rear left hand side of your airbox. It is supposed to have a hose attached to the sensor that runs down to a 3-way junction which has 3 hoses leading to your throttle bodies. Don't know why this sensor would be relocated to the intake snorkel. There is a sensor the same as MAP sensor on the intake snorkel but this sensor is the barometric pressure sensor.
I believe the MAP sensor is involved in altering the engines tune to suit environmental conditions at lower RPM (ECU Closed Loop mode). Closed loop mode operates at lower RPM's and idle, it uses data from various sensors to make adjustments to the engines tune on the fly. Once the engine hits a certain RPM or throttle position the ECU goes into open loop mode and its tune is based purely on the fuel tables that are stored on the ECU itself.Both 3-way connectors seem to go to the throttle bodies. I'm not sure why there are 2. I bought another T-connector from the auto parts store and joined the MAP sensor to the top T-connector (T-connector + T-connector = 4-way connector). I cleared the error by turning the ignition on/off a few times with the throttle open. The error doesn't come back when I start it up, but it doesn't if I disconnect the MAP sensor, either. Could there be a legitimate reason for why it was disconnected? What impact does it have exactly, besides the CEL?
How can the MAP sensor be used to determine which cylinder is on its compression stroke if it measures the air from all 3? Isn't the charcoal canister for the California-only evaporative loss control system? What do bikes outside of California have instead, a 3-way connector like mine?You need the map sensor. The bike uses this input for a few things but the most important is to determine which cylinder is currently on its compression stroke.
There are two sets of vacuum hoses because one set was used for the charcoal canister connected to it for the fuel vapor emissions return.
Are you sure that one the tips on the 4 way isn't broken off so it looks like a 3 way?
