So I put on a Akrapovic slip on and a K&N, then I took my bike to my dealer and told them to load a tune for it. it ran fine no problems. I then read a little while ago that tune ECU could disable the intake flapper i wanted to do that and also wanted to check that they put the right tune on. so I found a ebay USB cable for 8$ and I figured why not. (I would normally not do this kind of thing because i really don't want to mess up my bikes ECU.) so today I hooked the cable up to the bike and what do i find? WRONG TUNE! the dealer loaded tune 20312 a tune for a full arrow system and low octane fuel. (side note question-this tune still had the exup and the flapper enabled. why?) so i loaded tune 20281 high octane fuel and just a slip on, with the intake flapper disabled, i cant wait to try it now.
Tune ECU was sooo easy to use. If you install a slip on i highly recommend you go the tune ECU route and do it yourself. Im going to donate now because i am so happy with Tune ECU.
