So I finally had a bit of time today and tore into my 2011 Daytona 675R to check the valve clearances. After checking a few, I began to wonder what effect the temperature of the engine has on these clearance measurements. I know that the valve clearances are meant to be checked with a cold motor, but I thought this typically meant that the motor hasn't been run recently.
It was probably mid 40's (Fahrenheit) in the garage today, but the bike engine could very well be close to freezing. So, before I order any shims, does anyone have any insight as to whether my clearance numbers could be off because I'm checking them on a near-freezing engine? If anybody is curious, I've listed the clearance values below:
.35 .35 ----- .35 .35 ----- .28 .28 --- Exhaust (Spec: .275-.325)
.13 .13 ----- .15 .15 ----- .15 .13 --- Intake (Spec: .10-.20)
Additionally, if the temperature isn't a huge factor, why would my exhaust valves be so loose? I thought they tended to tighten up with use. FYI, my bike has 12000 miles on it with 3000 of those as track miles.
