Set of two freshly cleaned and modified fork cartridges with low miles. Dampers as new, Top caps with minor marks.
Compression and Rebound shimstacks modified to improve the underdamped OEM Fork. Come as on the pictures shown, shimming chart will be supplied. Wor best with 450cc 5wt fork oil per leg. Bleed holes are covered with tape as dirt protection.
For a supplement of 70€ the cartridges will be sent with mounted 8.5 (Std), 9.0 or 11.0N/mm (K-Tech)springs as a "plug&play" package, then installation is quite easy without the need of a spring-press or other special tool.
