perfect... will have to find a cable. any good sites to find a deal on one?You Can use the TuneEcu program and disable it.
Not surprising that some of these issues happen pretty consistently across bikes.Haha, I also have an 08 Daytona with 2k miles and the same squeek when I pass the same rpm range. I hadn't got around to investigating but I was suspecting the exup or intake flapper. So, cool that I spotted this thread.
T675.net to the rescue once again.
That's funny... Will give that a shot while I wait for my TuneECU cable to arrive. Amazing what a little shot of WD can do for you sometimes.I had this sound, drove me crazy! Found out what it was from here, sprayed a good amount of CRC (I think you guys use WD40?) and I have not heard it for 9000+ kms! :thumbup: Much easier and cheaper than disabling and removing it unless you really want to.
Pros; no squeak and less weight with one less moving part to fail and put up a code and one less line to follow if you ever have a vacuum leak.I'm having the same problem with my 08 675... i think some WD40 will be my choice, but out of curiosity, what are the pros/cons to disabling the intake flapper?
It's kind of a pain to get to i guess.Pros; no squeak and less weight with one less moving part to fail and put up a code and one less line to follow if you ever have a vacuum leak.
Cons; Err… Guys, I'm gunna need some help on this…
Sounds like it should work to me.Ok...I hope this doesn't cause issues. I took a shortcut/easy out. I took off the windscreen. Disconnected the the hose from the actuator. Plugged the hose with a small bolt and taped up. Taped hose to actuator. Put back together. No Flapper movement! Seems to be working. Please let me know if you see any problems with this. It sure beats the annoying squeak! So far so good! No error lights or running problems (short 2 mile ride to test).
