Arguably one of the lightest street-focused full-face helmets you can buy today, the EXO-ST1400 Carbon Fiber Helmet from Scorpion is perfect for the anywhere, anytime rider.
Each helmet is built using aresin-infused TCT-U 3K carbon fiber composite weave. This construction technique imparts a strong, frangible-resistant shell to which everything else is attached. And it's made in three different sizes so as to correctly fit a wide variety of head sizes.
On the shell are fitted user-adjustable intake vents and a large switch for deploying the built-in SpeedView sun visor. This particular feature means you'll never have to bring a spare shield if you're going one way with the sun up and another after the sun's gone down. This alone makes the helmet worth its weight in gold!
Inside, your noggin will be comfortably nestled in Scorpion's well-known Kwikwick anti-microbial interior. Not only is the liner comfortable, thanks to a well though-out arrangement, but also because of the integrated AirFIt inflation system. A moment to air-up the liner by squeezing the built-in pump is all it takes to achieve a custom fit every time you get on the bike.
Each helmet ships with an additional Pinlock-ready visor along with anti-fog insert, a helmet bag and a comprehensive instruction manual.
Backed by a 5 year manufacturer warranty and available in a range of sizes, be sure to get the correct one to fit you by calling
TJ on 866.931.6644 ext
817. You can also send a note to
[email protected] with SCORPION EXO-ST1400 CARBON HELMET in the subject line, or just shoot us a PM and we'll get back to you right away.
