1 - 4 of 4 Posts
· Premium Member
New for 2020 and designed specifically to meet the newest ECE and DOT safety standards, the Scorpion EXO-R1 helmet is a worthy companion for the most demanding riders.
Each helmet is built using a layered Ultra-TCT fiberglass/aramid (eg. Kevlar) and resin compound for a strong, lightweight shell to which everything else is attached. And it's made in three different sizes so as to correctly fit a wide variety of head sizes.
On the shell are fitted user-adjustable intake vents on the chin and forehead. These aid in keeping your head cool along with Scorpion's well-known Kwikwick III anti-microbial interior. Not only is the liner comfortable, thanks to a well though-out arrangement, but also because of the integrated AirFIt inflation system. A moment to air-up the liner by squeezing the built-in pump is all it takes to achieve a custom fit every time you get on the bike.
Each helmet ships with Pinlock-ready faceshields in clear and dark smoke, along with an anti-fog inserts, helmet bag and a comprehensive instruction manual.
Backed by a 5 year manufacturer warranty and available in a range of sizes, be sure to get the correct one to fit you by calling TJ on 866.931.6644. You can also send a note to [email protected] with SCORPION EXO-R1 AIR HELMET in the subject line, or just shoot us a PM and we'll get back to you right away.
· Premium Member
Discussion Starter · #2 ·
Scorpion designed the shell of the EXO-R1 for both stability at speed and maximum ventilation. Call 866-931-6644 to order today!
1 - 4 of 4 Posts
