Hey guys, I am replacing my head gasket for a couple of reasons. Head gasket sweating coolant, slight overheating [after idling in around -10c in a garage for 20 min it was at 6 bars.] The thermometer area is leaking coolant. So I presume the thermometer has gone and or maybe the water pump which built up pressure lifting the head for a second. Causing sweating.
Also thinking this might be my issue^
I am by no means a mechanic, so my diagnosis might be wrong.
Is there anything I should replace when I am in my engine other than the gasket?
Just want to make sure I'm not missing anything.
My bike is a 2010 675 if that helps. Also sorry for the bad photos...
Thanks in advance for any replies/help.
Sensitive content, not recommended for those under 18510.2 KB Views: 12
