They sell replacement bars but not just the delrin plug.
TJ,We've found it possible to re-use the OEM brake reservoir bracket, although in a slightly different configuration. All you need is a longer bolt to put it in place. Looks trick too!
Here you go KnollyWe've found it possible to re-use the OEM brake reservoir bracket, although in a slightly different configuration. All you need is a longer bolt to put it in place. Looks trick too!
