These are the final specs for the bike I just won the 2020 ASMA Amateur Championship on (at Arroyo Seco Raceway in NM). Development was constant for the first 2 years, but once I got it to my liking earlier this season I have not changed a thing. I have learned a lot and am here to answer your questions so you can get your bike set up well - at least that's my intention. I detail a good amount of these mods in my build thread HERE. I am also about to sell the bike and will update this post with the classified link HERE.
Chassis Setup: as a reference I'm 6'1", 200 lbs geared up, race mostly at Arroyo Seco Raceway, Pueblo Motorsports Park, and High Plains Raceway, Arroyo is pretty bumpy which did guide my setup to an extent. This bike started out as an '06 but is really a Gen 1/2/3 bike.
Engine Setup:
Other:
A few notes on the stock shock linkage which I detail in the build thread. I don't know if the swingarm pivot change helped or what, but I have data to show that my stock linkage is apparently VERY linear all the way to the bump stop. I am not clear on what everyone goes on about this bike needing a linear link because the stock linkage is so nonlinear. Not to say that a race link won't help but it does not seem to benefit riders due to the "more linear" nature of it because the stock one seems to be very much so (picture attached).
- Bottom of fork cap flush with top of upper triple
- 1.0 kg fork springs, 15mm or so preload including internal spacer
- K-Tech 20mm SSK piston kit (SSRK would be too stiff for bumpy track), 105mm air gap (their recommendation was 115mm)
- 2015 triple clamps (drops fork offset ~6mm, increasing trail)
- Swingarm pivot raised approx. 2.5mm by machining some Street Triple parts to fit frame - this was to increase swingarm angle only
- Rear ride height ~1.5mm higher than stock position (tried to get back to stock but was limited in shock adjustment)
- Penske 8983 dual adjust shock w/ remote reservoir
- 9.8 kg/mm shock spring, 10mm preload
- Rear axle is about at the middle of adjustment
- 15/49 gearing (48 rear for one of the tracks here)
- Pirelli SC1 slicks, 32 psi (f)/ 25 psi ® - keeping them low soaks up bumps well
- Hyperpro RSC steering damper
- Dropped clip ons 10mm below underside of top clamp to get me in the right position
- 2012 engine (had 7k street miles when I got it)
- Rebuilt head, 0.010" skimmed (max to be safe for stock cam timing), kit 0.60 mm head gasket
- Replaced all valve springs, added spacers - this was the UKRS kit
- Replaced valve retainers, collets, stem seals, lapped valves, other things I'm probably forgetting - all OEM parts
- APE manual cam chain tensioner
- Gen 2 velocity stacks
- Gen 2 headers, cat and exup straight piped up to Two Bros slip on
- K&N air filter, dyno tuned to 114.5 hp by Brian @ Speedin Motorsports in Farmington, NM
- Motion Pro Rev2 throttle assembly (running RR cam)
- UKRS billet oil cooler
- Yoyodyne slipper clutch, OEM plates
- Used cable to connect laptop to ECU to configure and also tune with TuneECU - I can link to a cable that ACTUALLY WORKS if you need, I tried 2 others that either worked once then never again or never worked
- SES steering stops
- Woodcraft clip ons (would go with another brand next time to be honest)
- Woodcraft rearsets (these are great)
- 2016 R6 calipers
- Accossato 19mm master
- Galfer rotors
- SBS Dual Carbon pads
- Shorai battery
