Fork seals are direct fit. I believe stanchions are the same. I think as long as the forks fit in the triple and axle is the same size, it should be no problem, right? Both 50mm uppers. I combed the forums earlier today and found nothing about other compatible fork sets. It seems like there should be some out thereI read about many R6 fork components swapping directly to 675 forks. I wonder if a complete fork swap would work... Would be nearly $300 cheaper than buying another set of Daytona forks.
What gen R6 are we talking about?Fork seals are direct fit. I believe stanchions are the same. I think as long as the forks fit in the triple and axle is the same size, it should be no problem, right? Both 50mm uppers. I combed the forums earlier today and found nothing about other compatible fork sets. It seems like there should be some out there
