1 - 1 of 1 Posts
Pit-Bull is an American Company based out of Alabama. They are extremely well known for their industry leading motorcycle stands. Pit-Bull is never sitting still and always developing new products and refining current products. They are now carrying steering dampers, sprockets, stands, jack stands, spools and many more products to boot.
The Pit-Bull steering damper has been out for over 5 years now. They went through some changes along the way, adding more adjustments to the stiffness, changing brackets so there was no-drilling required. Also for cosmetics they started anodizing the newer bike brackets Black. We have been using the steering dampers for years and we fully endorse the quality and craftsmanship of the product like many racers such as Eddie Kraft of Witchkraft Racing, and Danny Eslick of Geico Sportbike.
The steering dampers come in 4 different colors; black, red, blue and gold. You can go HERE to view all of the available bikes.
Every kit comes in a box that is well packed with each part in shrink wrap so no parts are banging against each other.
If you have any questions or would like to order a Pit-Bull steering damper give Jason a call at 888-784-4327 ext 210, or e-mail [email protected]
These kits come complete with everything you would need to assemble it, some kits require drilling and it will be noted, if it does they include the drill bit and the punch required to do so.
One of the nice things unlike any other damper we have seen is that the Pit-Bull comes with a hinging system that allows you to remove the bracket connected to the gas tank ONLY to remove the tank if necessary.
These dampers are top mounted with a center-hub design for even distribution and prolonged life. The tolerances are tight, and the machine work on the brackets to make sure nothing hits is phenomenal.
They go to many different methods to insure the bracing for the damper is solid, and to make sure everything fits perfect.
1 - 1 of 1 Posts
