1 - 7 of 7 Posts
I'm looking for 2 bolts for the front fender to replace where the bolt&reflector were, you cannot reuse that bolt as it is too long. Thanks for the help
you could use the bolt if you use a spacer. :whistle:
Yup, $8 each... :duh:
Ideally you would use a shoulder bolt to plug up the entire circumference of the bolt hole, but if you're removing the reflectors for aesthetic reasons, you can get dome head bolts from pro-bolt for $1.50 each
1 - 7 of 7 Posts
