41 - 60 of 72 Posts
· Premium Member
Discussion Starter · #43 ·
This is a replacement fairing stay for the 2013. You will continue to use the plastic scoop from the headlight assembly. On the 2006-2012 models it is the upper bracket only.
· Registered
Any idea on the weight difference between the stock subframe and the Motoholders?
Has anyone set up a motoholders subframe (and gotten rid of the plastic tray in the process) and have some advice as to how to make a battery tray and brackets for Bazzaz/PCV, etc.?
JB
· Premium Member
Discussion Starter · #45 ·
JB
You will save close to 5 lbs with the subframe. On our 09 we removed the trey, however on our 14's we had too much telemetry mounted under the tail and were not able to.
Here is a pic of the 09 with trey removed (all of the wiring was moved until the tank)
· Registered
Thanks, TJ. Wow, 5 lbs. Huge. Yeah, I kept the trey on my '08 bike as I liked having the space and attachment points for hook up the electronics and such. Could probably drop another 1 lb. or 2 getting rid of it, I guess. And I think for Supersport classes, you can't change out the subframe in most leagues. Superstock in my league (CMRA), you can.
· Registered
Still have race versions of the stay and subframe for a 06 D675? Does it have a place to hold the battery if I get rid of the tray?
· Premium Member
Discussion Starter · #52 ·
We stock both the fairing stay and battery box. The subframe is designed to work with the OEM tray (which holds the battery). If you do away with the tray you would need to find an alternate battery box.
· Registered
How do you attach the air scoop to the track version without the mounting tabs on the front?
If you run without the scoop would you lose O2 pressure in the air box and therefor lose power?
41 - 60 of 72 Posts
