1 - 2 of 2 Posts
Hi I own a 2009 triumph 675 street triple that I just bought. Have the check engine light for P1080. When I turn the key to ignitions it cycles through the valve couple times. Is there a way I can fix it? Doesn’t looks like it’s seized up.
I thought of installing the servo buddy I’m not sure how to do it. If someone can guide me through I would really appreciate it. When everything’s removed how to keep the valve open and all that. Thank you
Street Triples do not have an exup valve. Did you buy a Daytona conversion? Go to TuneECU.net get one of their recommended cables and use their free app and disable it in ecu. No need for a servo buddy. You will need to get it remapped however. If you want more info do a search in the Daytona forum section. There’s a ton of info.
1 - 2 of 2 Posts
