How-to: Install Race Cam Chain Tensioner
215564 Views 385 Replies 136 Participants Last post by  David CU
5
Here is my how-to guide for replacing the OEM cam chain tensioner with the official Triumph Race Cam Chain Tensioner kit. I apologize for not taking photos.
Purpose: To race modify your bike for racing and track day use, or as in my case, to eliminate once and for all the annoying buzzing/rattling from the cam chain. If you suffer this noise, which is fairly obvious and sounds like a rattle or buzz that occurs between 6000~8000 RPM and comes from the right upper side of the engine, near the handlebar area, you can eliminate it with the race CCT. The OEM CCT will only apply so much tension, and if your cam chain loosens over time, sufficient tensioning may no longer be applied by the OEM CCT, and at these RPMs the cam chain can actually start to rattle against the insides of the crank case, creating a very annoying sound. It could cause possible damage if left unchecked, leading to the cam chain snapping (as it did in my case). Although this issue has never been formally addressed by Triumph, they have in fact replaced their OEM CCT in the new for '09 Daytona with a new type. I recommend this mod to anybody experiencing the cam chain rattle/noise because it is an inexpensive and fairly simple fix to a potentially devastating and annoying issue with our bikes.
What You Need:
Race Cam Chain Tensioner ($105) from www.pure-triumph.com or ($52) from http://www.aperaceparts.com
Basic tools (metric sockets, wrenches, nothing you won't already have from tooling on the 675).
Opening the crank case:
1. Leave motorcycle on side stand, in Neutral and allow to cool completely. Remove only the right side fairing.
2. Remove the crankcase cover bolts, and make note of the one with the copper sealing washer (it is obvious where it goes when you put it back together).
3. Remove the crankcase cover and the crankcase sealing gasket. Clean the gasket of any oil and put aside for later. (If gasket is in poor shape you should replace it with a new one. It does not require silicone gasket maker sealer.)
4. Using a socket wrench (24mm socket), turn the crank clockwise until you reach Top Dead Center (TDC) which is when the little dot on the gear (1) lines up with the marker line (2) in the engine case.
5. Find a suitable wedge (piece of wood, rubber tubing, rag) to wedge between the cam chain tensioner guide and the crankcase wall to keep tension on the cam chain so it will not move when removing the old cam chain tensioner.
Removing the old tensioner:
1. Remove the center nut on the CCT and remove the spring inside it.
2. Remove the two bolts securing the CCT and remove the entire CCT unit.
Installing the Race CCT:
1. Assemble the Race CCT if necessary by putting the small o-ring on the long plunger bolt and apply some oil to it and thread it through the race CCT body. Thread it all the way through so that it is in it's fully backed-out position (as pictured below). Loosely thread the lock-nut to the threaded part of the plunger bolt. Apply the large o-ring to the Race CCT body and apply some oil to that o-ring as well.
2. Install the Race CCT and secure it with the two bolts provided. Torque to 9 N-m.
3. Hand tighten the plunger until you feel it meet some resistance when it contacts the cam chain tensioner guide (you won't see it so you have to go by feel). When you are sure you have hand-tightened the plunger up against the guide, you can safely remove the wedge you were using.
4. Now (using a 24mm socket) begin turning the crank again in a clockwise direction while applying light hand-tightening pressure on the plunger. Whenever there is slack you will feel the plunger tighten, that is, it will screw in bit by bit as it takes up the slack while rotating the crank. Continue until the plunger no longer tightens/turns while rotating the crank and all the slack has been taken up.
5. Now back the plunger off 1/4 turn.
6. Now tighten down the lock nut to a torque of 9 N-m, and make sure the plunger does not turn while tightening the lock nut.
Reassembly:
1. Put the crankcase gasket in place. (Clean it off of any old oil that may be on it.)
2. Put the crank case cover in place, and secure with original bolts to a torque of 9 N-m. Make sure to replace the copper washer to it's appropriate location.
3. Replace the right side fairing.
4. Ride or race!
Conclusion:
I have done this mod and my cam chain noises, buzzes, rattles, vibrations - whatever we call them - the annoying stuff that our bike does between 6000~8000 RPM have been eliminated! This has to be one of my favorite mods as a result because the bike is simply perfect again. It's also nice to know that if the buzz comes back for any reason, it's easy enough to re-adjust the Race CCT to take up any new slack that may occur in the chain, keeping the chain buzz free and safe from damaging itself.
I hope this how-to is of use to anybody wishing to do this mod. I am not a mechanically inclined or engine person at all and I was able to do this mod with no trouble... so enjoy!
  • Like
Reactions: 2
321 - 340 of 386 Posts
APE Manual CCT...
I've been noticing that my APE manual CCT is leaking a little oil lately.
It is coming from the threads on the adjusting rod itself.
There is nothing to stop this oil leak and nothing to stop the oil slowly seeping up along the thread on the adjuster rod.... as far as I can see.
Anyone else notice this happening, and if so, how did you fix it? Is there a fix?
S.
yeah i know there not related but before i took it to the dealer i wasn't sure my exup cable adjuster was broke so to cpu couldn't set the cable slack so i got new cables coming in because i dont want to remove exup until i get a proper slip on and modify my headers
And I think my cct is set right because i did the 1/4 turn out and the engine sound normal i was just worried cuz i started reading stories of engine failures and such. anyway thx for reply
S.
There is an O ring between the locknut and the tensioner body but after a few adjustments it gets chewed up on the threads.
You could back the locknut right off while holding the main bolt clean it up with carby cleaner etc. and put a dab of loctite 515 or any other non rigid setting gasket goop between the nut and body.
Of course you will have to reapply every time you re set the CCT
There was no O ring between the locknut and tensioner body on my APE. There never was.
There is the OEM O ring on the inside of the tensioner body inside the motor, but none on the outside.
I've checked the pictures of the APE tensioner and none of them show an outside O ring.
S.
my ape had an o ring on the outside between locknut
Hmmm...very strange...
I can see what I will have to do.
Thanks for the feedback.
S.
my APE tensioner also leaks oil out the main rod threads (mine does have the little o ring) and oil is leaking past the inside tensioner body o ring. all i do to clean it up is squirt it with brake cleaner once a week or whenever it needs it. no significant oil level loss has ever occurred.
Gah I need to order one of these
Powered by Hellfire and Damnation
I pulled mine apart and had another look at it.
The O ring was missing but the machined indent where it is supposed to sit was there...
Well then, I removed the nut from the end of the adjusting bolt, and fitted a new O ring.
Hopefully, that will be the end of the slow oil leak for a while.
S.
Just another data point, just installed the APE CCT, mine did not come with an o-ring for the locknut area. Guess I'll have to monitor for leakage. Seems like APE has a QA issue.
Fitted the APE CCT today. It did come with the lock nut o-ring, but I had to use the OEM o-ring for the main body seal - no problem. Thanks to the contributors to this thread which made this install very easy and problem free.
No leaks...
Regarding my oil leak from the adjuster bolt on the CCT....
After replacing the small O ring twice and still getting oil leaking through the threads on the adjuster bolt... I decided to take a different route to put an end to the leak.
After removing the manual CCT from the bike, I removed the damaged O ring from it's groove.
I then cut the pinned nut off the end of the adjuster bolt and using a Dremel with a cutting disc, I cut a screwdriver blade slot in the end of the adjuster bolt.
When I reassembled the CCT I used red high temperature Permatex Silicone on both the adjuster bolt threads and also smeared some into the groove where the small O ring would normally go.
I didn't use an O ring, just the red Permatex silicone.
I had already replaced several small O rings so I couldn't see the point of using another one only to have it fail.
Now, after doing all this, I have no more CCT oil leaks.
I've done quite a few good hard runs of about 200 kilometres each and still no leaks.
I think that this time, I have it by the short and curlies!
S.
Anyone have the pictures anymore?
I think page 11 has pics
I know this is not the right forum for my specific bike, however its one of the few walk through I can find for a Daytona. Do any of you know if I can use this for changing out a tensioner in a 99 Daytona 955i? I would imagine the torquing specs would be different, but can I just take of the crank case cover off and follow this for the 955i?
How would one know if it's too tight? I'm better to er on the loose end I'm assuming.
Rid my chain noise but now I have a new noise under decel @ 4k rpms to 3.5
Yes, better a little loose than tight. Too loose and you could throw the chain, but you would pretty much have to leave it completely loose for that to happen. You can feel and hear when it's too tight. The chain makes a different buzzing sound if running, and if cranking by hand, just feels like it's binding. As you turn the engine, just keep tightening with your fingers until you can't anymore. You will feel the loose and tight spots in the chain. Tighten to the loose spots. Once you have done that, back it off a half or so. Good to go.
S.
Spook, hate to break it to you - but you were supposed to use the o-ring from the oem tensioner that was in there originally. Though permatex/yamabond/whatever will work fine too.
Mate....I did.
There are two O rings on the manual tensioner. One which seals the tensioner itself and the small O ring which fits into a groove cut in the body which is designed to seal the adjuster bolt.
It is this small O ring which causes the problems.
The threads on the adjuster bolt cut into the rubber O ring and oil [under pressure from the motor] is able to work it's way along the adjuster bolt threads past the small damaged ring.
This is where the oil starts leaking from....the thread on the adjuster bolt.
My manual tensioner did not have the small O ring on the thread originally. Someone at the assembly plant forgot to put one on there.
Anyways, all is well now that I have sealed the adjuster bolt thread with the red Permatex.
I currently have over 123,000 K's on the original motor and she still goes like a rocket!
S.
Ah, I understand - mine came with one on the threads (under the locknut) but not the sealing one on the cct body itself.
To those who are just running this mod, it might be wise to pick up a better quality o-ring at a bearing or fastener shop - viton or something more durable. Alternatively do what Sp00ky did and use some yamabond to seal under the locknut. Mine doesn't leak but I've heard it happens to some.
