1 - 11 of 11 Posts
My fan comes on as soon as I turn the key. I'm only showing 3 bars on the temp gauge. Is there a cooling fan relay or is it controlled through the computer? I check the fuse and it's good. Also I have a 11 D675
I checked out the resistance on the service manual and its says the coolant temp sensor should have a resistance of
2.9-3.3 K ohms. I am only getting 1.7. Im guessing this is my issue with my fan staying on unless I missed something.
Discussion Starter · #5 ·
So, i just finished installing the new coolant sensor. The resistance is within specs now. That fan is still turning on when i
turn the key. I get 1.2ohms at the fan motor but the fan runs so that shouldn't be the issue right? I followed the wiring
diagram and i don't seem to have any shorts. Could it be a ecm issue?
Discussion Starter · #8 ·
problem fixed.... I put in a new ecm and everything is working. No codes and the fan comes on when it's supposed to now.
It sucks that it's raining now, I want to go for a ride.
Thanks for your help guys.
P1552 - 08 Triumph Street Triple
I was riding home from Long Beach to San Diego at night and my bike started having a pulsing headlight and some electrical issues.
I pulled over ad turned it off to check it out. I saw the battery terminal came loose and so I resolved that. Turned the bike on and it was weak batter but turned over. I noticed the engine light was on.
OBD2 scan says P1552 - Cooling Fan Short Circuit / Open Circuit
It looks like my cooling fan is not running, so now what do I do?
I'm looking at my Haynes book now trying to see if I could find a wiring diagram.
Seems this is not too uncommon. Any thoughts?
#1 - 15A Fuse to Coolant Fan looks good.
#2 - Relay 2 = 94.5 Ohms open. Applied 9v Battery to close = 0.3 Ohms. Relay 3 = 96.7 Ohms OPEN. Applied 9v Battery to CLOSE = 0.3 Ohms.
What is the next steps?
Hey mate did you get an answer as mine is doing the same
1 - 11 of 11 Posts
