qweesy, do you like the dyna beads? Did they perform as well as they are made out? I'm about to use them on my new set of tires and still iffy about them.
Yes I like them alot i will not be going back to static weights, dont have to worry about them falling off or looking like poo....and the tires are balanced for the life of the tire.
the tires are not balanced at 5mph or lower but your only doing that in a parking lot and the Michelin PR2's ive had been pretty good off the bat needing very little weight or no weight at all.
The beads are pretty cheap, you can save them if you want for the next tire change but i don't even mess with that I just buy a new set.
Oh and if you get em don't even fuck with trying to put the beads through the valve... PITA and I spilled a 1/4 bag trying to do so.....they said it would help if you put a vibrator next to the valve...........uh I don't have a fuckin vibrator:laugh:.
So what I do its put the new tire on seal the bead on both sides pop one side of the tire bead throw the dyna beads in 1oz front and 2oz rear and seal the tire bead back up:thumbup:alot easier
