1 - 3 of 3 Posts
· Registered
Trying to put on rearsets and change to gp gearing but I ripped the bolt above the kickstand the 8mm hex which looks to be going into the block and it won't come out it's just turning. Won't tighten either. Il attach a pic of the bolt. Anyone have a similar experience? The oil around it is WD-40.
Tire Wheel Automotive lighting Automotive tire Vehicle brake
· Registered
That's one of the engine mounting bolts. It goes all the way through to the other side of the motor. It's turning because there's a nut on the other side. You need to hold the nut with a spanner and then undo the bolt.
Thank you I feel a bit stupid now but it's my first proper bike😅 I was getting worried do I walked away from it last night 🤣
1 - 3 of 3 Posts
