That looks dope! Where does one mount the billet, could you send a pic if possible please? Also - does the gear shaft support get hidden behind the front sprocket cover or does the front sprocket cover not fit over it?Hi and welcome aboard.
I recommend getting these 2 parts to start with...
Triumph Racetorx Gear Shaft Support
We often find when rearsets are fitted extra strain is put on the gearbox selector output shaft. This can lead to poor gear changes, seal and or shaft failure. This simple to fit device add extra support to the shaft enabling better shifting. The internal needle bearing is protected by seals...www.ukracesupport.com
Triumph Daytona 675/R & Street Triple/R 2006-12 UKRS Billet Oil Cooler
Triumph Daytona 675/R 2006-12 & Street Triple 675/R 2007-12 TRS Billet Oil Cooler Now with new Sealing Plugs for radiator and water tube blanks. Sooner or later any 2006/12 Daytona or Street Triple 2008-12 used on the track will blow its heat exchanger. When it goes which will be without...www.ukracesupport.com
Just purchased both. Thanks.Hi and welcome aboard.
Geez, what an intro. What do you ride? Post up a pic of your bike. You sound like a scammer.I’m new here
