Yes it will. The only difference is that the outlets for the breather/overflow hoses is 2mm bigger than the '07. Therefore it may take some finagling to connect the rubber hose on (or you can just replace them with an '09+ set).tom do you know if this fits in the 07 era tank ?
gotcha, im going to wait to pull the trigger on this for now.Yes it will. The only difference is that the outlets for the breather/overflow hoses is 2mm bigger than the '07. Therefore it may take some finagling to connect the rubber hose on (or you can just replace them with an '09+ set).
