Is that the one with the lever you pull down to compress? Yeah that one's decent if you have someone helping you. Damn near impossible by yourself though. TFSC 01 is a cinch by yourself but it is on the expensive side.They also have a much cheaper manual tool. I want to say it is somewhere around $40. The P/N for it is TFTT 01
Yah it has two handles you pull down on. Definitely takes two people. One to pull down (with all their might) and one to slip in the cartridge rod holding tool. The first time I used the TFTT 01 I rigged up some thing with a ratchet strap to compress the spring. I have used both and recommend the TFSC01 or TFSC02. I just wanted to point out that there was another option if you are on a budget. I am sure you know MGFChapin, but others may not. The tools get more expensive as you scroll down.Is that the one with the lever you pull down to compress? Yeah that one's decent if you have someone helping you. Damn near impossible by yourself though. TFSC 01 is a cinch by yourself but it is on the expensive side.
