I recently replaced my front turn signals with proton flush mounts. I was not excited about having to cut the connectors off (thereby trashing them) the stock signals for use on the flush mounts, so I set off in search of the stock connects. Bikebandit turned up nothing, but I was able to source the connectors from a local electronics shop (they also sell online). This way your stock signals can be saved in case you need to put them back on.
Here is the info on the connector and the link.
http://shop.willyselectronics.com/b...093-1-circuit-free-hanging-socket/4,9212.html
Multi-Pin Connector: 0.093" 1 Circuit Free Hanging Socket
Item #: 61-241
Multi-Pin Socket: 1 Circuit
Specifications:
Type: Multi-Pin Connector (Molex-Type)
Pin Size: 0.093"
Maximum Connections: 1
Connector Type: Free Hanging
Quantity: Connectors -- 2
Pins -- 2
Manufacturer: Philmore
Note: Picture below is of the 0.062" size but the 0.093" look identical.
Item #: 61-241
Specifications:
Pin Size: 0.093"
Pins -- 2
