I'm in your shoes now. I've decided to save up for the Tuneboy and then get a full system.
It's your choice: full or slip-on. Do you want looks? Do you want more power?
If you get a full system you will need to get a Tuneboy or the like. There are custom maps available but the best option is to have a shop tune it for you. Then you will take full advantage of the power of the full exhaust.
I don't know of plug and play ecu for the 675. Powercommander will let you load a new map. I'm not sure if the ECU adjusts the F/A ratio on the fly based on the O2 sensor.
Tuneboy will allow you to change your map and help with diagnostics. I wouldn't buy a full system without already having a Tuneboy or Powercommander. It will ride worse than the stock. How much worse? I dunno, but it's a dumb idea.
I don't think that reliability goes down with a full system (even with removal of EXUP). Gas mileage might.
Hope this helps.
Hope this helps.
