Mine was on the rear set side, I know it doesn't look like it but there is room for it to slide through the hole in the frame.Which side of the frame do you set the qs on? Closer to the engine or the rear set? I don't know how big the qs is but it doesn't look as if there is enough room between the rear set and the frame.
what did you do to shorten the linkage?Mine was on the rear set side, I know it doesn't look like it but there is room for it to slide through the hole in the frame.
Took it to a machine shop and told them that it needed to be exactly the same, just 2 inches shorter. :biggrinjester:what did you do to shorten the linkage?
haha easy enough! :nod:Took it to a machine shop and told them that it needed to be exactly the same, just 2 inches shorter. :biggrinjester:
