I have the head off for valve work on my 2014 Daytona 675R. I have a new head gasket, but the manual says to also replace the "barrel" (cylinders) base gasket too. Is the base gasket as critical to replace?
The manual instructs to split the cases and remove the pistons in order to replace the base gasket, which I'd like to avoid if possible. It seems it might be very difficult (or impossible?) to get the cylinders back over the pistons without splitting the cases. I'm thinking trying to get a ring compressor or fingers inbetween with a short stroke will be tough.
I'm leaning towards replacing the gasket since it'd be pretty awful for it to leak and having to tear the engine out of the frame again and buy new head gasket/nuts which are over $100. Just want to know what I'd be getting into either way..
