1 - 13 of 13 Posts
· Premium Member
The Supersport clutch lever kit from CRG is not your average clutch perch, but rather a simple high-quality replacement for your OEM clutch perch and lever. Its dual 16mm bearings provide a seamless lever feel that can help you improve your green flag / green light performance off the line. As with all CRG levers, length of reach is adjustable via a large red adjuster rheostat located near the lever's pivot joint. Clutch play can easily be adjusted via the same kind of index knob found on most OEM perches. Dialing in the right feel is made possible with an adjustable clutch lever ratio function which can be set in one of three positions to suit almost any rider's taste. Plus, you probably won't have to modify your motorcycle's wiring as these kits accept the installation of OEM clutch safety switches for most late model Yamahas, Hondas & Suzukis.
Just like all other CRG parts and accessories, CRG Supersport clutch lever kits are precision machined from 6061-T6 aluminum and tumble-polished for a smooth, snag-free finish.
Available in gray (shown), black or gold finishes with either shorty or standard length levers, call TJ at 866-931-6644 ext 817 to order. You can also send an email to FORUM at RIDERSDISCOUNT dot COM with the subject line CRG SUPERSPORT CLUTCH KIT in the subject line - be sure to specify what color and length you want and we'll get back to you right away.
The Supersport Clutch lever kit.
Built with CRG's proven adjustment mechanism for a perfect reach to the clutch lever.
Simple adjustable receiver for varying lever ratio. Notice the brass plate, which allows the installation of the OEM clutch safety switch.
High-quality stainless steel hardware is fitted as standard.
A simple universal installation fits all late-model sportbikes with 7/8" diameter bars.
· Registered
UGH, STOP IT.
I have a winter mod list of a bunch of things to buy from you once my job is set in stone, and there are just WAY too many things on it that I add and say "yeah might as well throw that on there too." :laugh:
PREPARE YOUR UPS ACCOUNT
· Premium Member
Discussion Starter · #9 ·
Bringing back an old one. The Supersport clutch perch accepts Honda switch part# 35335-MCJ-750, Yamaha switch part# 4XV-82917-01-00, Suzuki switch part# 57560 0500. We never tried a Triumph sensor as all of our bikes had race harnesses that did away with the clutch switch.
· Registered
Do you have any of these in black standard lever, in stock? Thanks!
1 - 13 of 13 Posts
