hey all... this is my first post on the forum...
my bikes a 2008 daytona 675, and i live in oakland/bay area...
i love this bike a lot, but recently i’ve been having issue after issue , mostly related with the charging system, and i can’t tell you how many times it’s left me stranded.... anyway so i’m gonna try and explain my current symptoms the best i can, and keep it short and to the point...
ok about 2 months ago bike wouldn’t start and i noticed it was
only charging at around 13v... i kept putting off replacing the stator, and instead would either make sure to park it on a hill where i could jump it, or i started carrying a small jump box with me, and would just use that to start it up... it got to a point where i was getting no charge whatsoever, and i finally just ordered a new stator and r/r...
when i pulled the old parts i did notice the stator plug had melted, which is where the probs came from..
so i installed new parts and everything was great... 14+v’s charging, and things were great for like 4 days... then my bike wouldn’t start... i inspected things and found that same plug had melted again...
contacted seller, and they sent me a new r/r. i installed this one, only this time i hard wired it to the stator. i went to start it, and it just now cranks and cranks.. won’t fire.
my first thoughts were the crank position sensor... i checked resistance and it’s around 200ohms... then with my multimeter on ac, i had a friend crank the engine while i probed the cps connector, and i am def seeing a small voltage spike...
i also tested the same wires at the ecu connector, to make sure there wasn’t any breaks in the wire and the signal was actually reaching the computer... all good.
i pulled the air box, and checked for
spark at the plugs... nothing...
now here’s something interesting....
yesterday before pulling the airbox, i did get the bike to fire up... and as it was idling i lowered the tank, and as soon as it lowered completely, the bike shut off instantly, and since then i haven’t been
able to get it started back up... with the tank up, down, nothing...
anyone have any ideas on what i can
check next? this is getting real old at this point, esp being that it’s my only transportation...
ok thx in advance
ok thx in advance
