1 - 4 of 4 Posts
Will any of the crank cover gaskets work or do they differ between gens? I have a gen 3 daytona, could I use a gen 2 street triple etc?
the 13+ crank cover is totally different. you can make one pretty easy. Is it leaking? Try just tightening the bolts first. Use the crank cover as a template and get two bolts in it then tap the edges to make an impression.
no, I took the cover off to inspect my cam chain tensioner guides and ruined the gasket in the process. Thanks, ill see if my dealer has one and if not Ill make my own
1 - 4 of 4 Posts
