1 - 6 of 6 Posts
Discussion Starter #1
Hey guys, I have a Daytona 675R 2012 and I'm trying to remove the after-market exhaust so I can put on the OEM version.
The problem is, I was able to get everything detached EXCEPT for the exhaust pipe as seen in the attached pictures. I tried pulling as hard as I can but I can't seem to get the dang thing off. Any ideas on how I can separate these two pieces? I've removed the ring around it but that didn't seem to make a difference.
Can you rotate the pieces at the joint? It's amazing how hard a little road grime can fuse slip joints. Maybe a little penatrating oil or brake clean into the vertical slot on the upper pipe just to try and loosen things up. Good luck
Discussion Starter #3
I can try and get creative to see if I can rotate it. Maybe that will shake some off some of the gunk. Thanks for the tip!
Discussion Starter #5
Looks like soaking it in some penetrating oil and twisting it back and forth did the trick, thanks everyone!
1 - 6 of 6 Posts
