I’ll keep searching but yeah it was running with no problem before I took it apart.Try using the search. There are a few threads on the subject. Does the bike run properly?
Camshaft/TDC markings not lined up
Need to adjust a valve. yes just one. before I pull the cams, Just want to know how close the camshaft markings need to be lined up. Have seen some other posts about them not lining up exactly. the bike runs fine. When I reinstall the camshafts, should I line the marks up, or reinstall them...www.triumph675.net
Yeah, so what I’ve seen so far is that it should be fine I guess I’ll just do my shims put it back together and hope for the best thank you.They look okay. You would know if they were out of spec because the bike would run like crap.
One more question, should I expect the idle to be strange until the ecu figures itself out from having 6 different shims on the exhaust?You don't need to hope. It WILL be fine.
Sounds good I’ll give that a try. Thank you.Reset the adaptions using TuneECU or let it idle without touching the throttle until the fan kicks in.
Again so sorry for all the questions but i just get to paranoid. When I had first taken it apart the camshaft lines were lined up, but the crankshaft dot was nowhere to be found. I saw on other forums that this could mean a stretched cam chain? With the dot lined up, the cam lines are all whack.Reset the adaptions using TuneECU or let it idle without touching the throttle until the fan kicks in.
Again so sorry for all the questions but i just get to paranoid. When I had first taken it apart the camshaft lines were lined up, but the crankshaft dot was nowhere to be found. I saw on other forums that this could mean a stretched cam chain? With the dot lined up, the cam lines are all whack. View attachment 261451Reset the adaptions using TuneECU or let it idle without touching the throttle until the fan kicks in.
darn yeah, the bike is just below 12k hence why I’m here in the first place. On the other thread someone said half a tooth wasn’t a big deal?From the photo it really does look like both your intake and exhaust camshafts are off by a tooth. Your chain probably has stretched enough so when the markings on the cams line up, the crank is off by half a tooth.
Yeah, I get that. I was confident doing this just didn’t expect any hiccups. I’m just getting too paranoid about ruining it. I’ll try that though thank you.I would adjust it so the marks line up, but ..... I know what I'm doing, and leaving it would just bug me. If you're unsure of your skills and the bike runs, leave it alone. There are very few circumstances worse than breaking something in an attempt to make them better.
I have to assume it is as I bought the bike from the original owner and he told me that the cams were never messed with. and I have all the service records and shows nothing of the valves. so this is the first time it’s been apartAre you sure Timing chain isn't stretched too much? Also get manual chain tensioner, the hydraulic one is no good.
Yeah I checked the clearances b4 disassembly and had to do all my exhaust shims which I switched out. I’ll order manual tensioner today most likely and look into a chain.Ok I would order a new timing chain, mine was stretched when I did my first service. Get if a manual timing chain tensioner if you hadn't already.
Also check your valve clearances before you unbolt the cam ladder, you may get lucky and only have to swap buckets.
Yes get it all lined up as best you can , unbolt hydro tensioner, remove old chain, drop down new chain line up marks Top and bottom, bolt down cam ladder in proper order follow service manual, apply tension with manual tensioner til taught back off a turn.Yeah I checked the clearances b4 disassembly and had to do all my exhaust shims which I switched out. I’ll order manual tensioner today most likely and look into a chain.
When installing a new chain would I just line everything up as it should be and go from there?
